I think this is the key you want. Otherwise left outer joins crash often:
HKEY_LOCAL_MACHINE\SOFTWARE\Business Objects\Suite 11.5\Crystal Reports\Database\QueryBuilder\OuterJoinEscSeq
I'm pretty sure I had to add the key called OuterJoinEscSeq since it was not there by default. Then add a string with name NoOuterJoinEscSeq with a value data of pgoe1022 (which is the driver name)
Also note that if you are not using Crystal XI R2, I think you will find Suite 11.0 instead of 11.5.
-Adam
-Adam
--- In vantage@yahoogroups.com, "Dan Shallbetter" <dans@...> wrote:
> Looking for the odbc left outer join registry fix for progress 10.1b. I
> have the script for odbc kit, it references a Crystal Decisions
> registry key that I do nnot have?
> Thanks,
> Dan Shallbetter
> States Electric
