Gary,
I am pretty sure it does, because we have always (and still do) used Procontrol and it works fine.
For those upgrading to a new version of Vantage (while in training/test or with your live database), running your schema changes in Single user mode runs ALOT faster also. (Performance tip for upgrading.) Sounds like a lot of companies are preparing to upgrade these days.
Troy Funte
Liberty Electronics
Troy Funte
Liberty Electronics
----- Original Message -----
Sent: Thursday, February 20, 2003 1:39 PM
Subject: RE: [Vantage] Re: License issue v5.2
Troy,
Does this work with 4.0?
Gary Polvinale
Sent: Thursday, February 20, 2003 11:14 AM
Subject: Re: [Vantage] Re: License issue v5.2
Todd,
Another option to keep users out while you do Vantage Admin stuff is to
shut down Progress Explorer, then access Vantage from a "Single User" mode
icon. This would be a copy of your regular Vantage.vtg icon, except that
you replace the "Connections=-N TCP -H host -S epic52 -ld vantage" line to
just "Connections=-1". This opens Vantage in single-user mode (which only
works with the database shut off).
Troy Funte
Liberty Electronics
Sent: Thursday, February 20, 2003 10:55 AM
I will try that next time. Which will be at 11:30 (lunch time) today.
Because....when I entered all the license codes I missed the Order
Management codes and now that everyone is back in the system I can't enter
it. It requires that I be the only user in the system. The next best
window to do this is lunch. Then I'll have to walk the shop again and fix
all the DC PC's that I will have to ProMon out.
At least for us this was a quick fix issue and the total down time was
about 45 min. My sympathy to the earlier sites that were down much longer.
-Todd C.
[mailto:michael.j.moloney@...]
Sent: Thursday, February 20, 2003 9:54 AM
Todd:
You can unshare your Vantage folder while you are working with the license
issues to keep other users out.
Mike Moloney
(Embedded "Todd Caughey" <caugheyt@...>
image moved 02/20/2003 09:56 AM
to file:
pic14295.pcx)
Please respond to vantage@yahoogroups.com
To: <vantage@yahoogroups.com>
cc: (bcc: Michael J. Moloney/USWIN01/Power/ALSTOM)
Security Level:? Internal
We are in the midst of this right now. Epicor Support sent me 4 files and
Ijust ebtered the response code but somebody in the plant tried to get
into
Vantage inbeyween kicking them out and my entering the response so the
license file was locked up. Arrrrrgh! So now I'm on hold waiting for
support to give me a new response and try again. In the mean time I'll
bet
someone else tries to get in and screws it up again.
On the bright side patch 312 is supposed to be out today or tomorrow and
has fix for this issue. From the sounds of it 311 was supposed to fix it
so the files they send are different for 305 vs. 311. Apparently a lot of
sites are reporting this.
Todd C.
Sent: Thursday, February 20, 2003 8:39 AM
Hey guys, guess what? Count me in as one more user with the corrupt
license
problem. Yesterday AM all my users got the error. Called support and was
emailed two files, VNTGMENU.r and Vntgmenu.wrx. Was told to put them in
my
Vantage folder. I was then given an unlock code to enter into the
response
field that appears in the error message box. After the code was entered I
had to reenter all the module codes(what a pain). I was down for a couple
hours. Everything seems to be OK? We are on 5.20.305.
Mark Dupuis
Sent: Thursday, February 20, 2003 8:55 AM
To: 'vantage@yahoogroups.com'
Britt:
What did you do next since you still had the corrupt license issue? Did
you
go back to .308? Did Epicor provide you with a solution?
Regards,
Scott
Sent: Tuesday, February 18, 2003 11:45 AM
We were at the 308 patch and got the error. We then loaded the 311
patch, entered all the license codes, and about an hour later it came
back!!!
Sent: Tuesday, February 18, 2003 8:49 AM
We are at patch level 5.20.305, but will be upgrading to 5.20.311 today.
Which patch level are you at?
I was told that anything less than 308 would give you this corrupt
license issue
Go to the 311 patch if you can ASAP
Yahoo! Groups Sponsor
ADVERTISEMENT
http://rd.yahoo.com/M=245454.2994396.4323964.2848452/D=egroupweb/S=170500718
3:HM/A=1457554/R=0/*http://ipunda.com/clk/beibunmaisuiyuiwabei
http://us.adserver.yahoo.com/l?M=245454.2994396.4323964.2848452/D=egroupmail
/S
:HM/A=1457554/rand=181571885>
have
Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <
http://docs.yahoo.com/info/terms/> .
ADVERTISEMENT
(Embedded image moved to file: pic32168.gif)
(Embedded image moved to file: pic20825.gif)
have
CONFIDENTIALITY : This e-mail and any attachments are confidential
and may be privileged. If you are not a named recipient, please
notify the sender immediately and do not open any attachments
hereto,
disclose the contents of this e-mail or the attachments if any
thereto, to another person, use it for any purpose or store or copy
the information in any medium.
ADVERTISEMENT
<http://rd.yahoo.com/M=245454.2994396.4323964.2848452/D=egroupweb/S=17050071
83:HM/A=1457554/R=0/*http://ipunda.com/clk/beibunmaisuiyuiwabei>
<http://us.adserver.yahoo.com/l?M=245454.2994396.4323964.2848452/D=egroupmai
l/S=:HM/A=1457554/rand=668125183>
ADVERTISEMENT
ADVERTISEMENT
