Limit records being loaded in UltraCombo field
That was it,
Mike
bw2868bond
Sent: Thursday, January 03, 2013 8:34 AM
Subject: [Vantage] Re: Limit records being loaded in UltraCombo field
Change Like to MATCHES
Change % to *
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Mike
Numbers" wrote:
> Just getting back to this after the holidays.
> I changed -
> > string whereClause = String.Empty;
> To-
> string whereClause = "RoleCode like 'Eng%'";
> When I open the program I get the following message-
> Invalid query: where Company = 'CIGNYS' and (RoleCode like 'Eng%') BY
Name.
> No records are then being passed through the adapter.
> Mike
Behalf Of
> Mark Wonsil
> Sent: Wednesday, December 26, 2012 9:29 PM
> Subject: Re: [Vantage] Re: Limit records being loaded in UltraCombo field
> Hi Mike,
> > System.Data.DataSet dsSalesRepAdapter =
> > Epicor.Mfg.UI.FormFunctions.SearchFunctions.listLookup(oTrans,
> > "SalesRepAdapter", out recSelected, false, whereClause);
> You're filling the combo with a query but the query condition
(whereClause)
> is set to blank. Try setting it to something like:
> It's not a C# thing really, you just need to pass the adapter the correct
> selection.
> Mark W.
9.04.507a
I have added an UltraCombo object being loaded from SalesRep to the Part.entry program. I followed an example in an old student manual and everything is working the way it is supposed to. My problem is I don't want all of the records in the SalesRep table, I only want records that the field SalesRep.RoleCode start with "Eng". Can someone show me how I can add code that will do this. It seems like it should go in the script that gets created from the wizard, but with my C# knowledge, I don't see how to do it. Any help would be appreciated.
Depends on the code you used, can you post it?
Jim Kinneman
Encompass Solutions, Inc
--- In vantage@yahoogroups.com, "mike.numbers" <mnumbers@...> wrote:
> 9.04.507a
Below is the code in Customization Tools Dialog / Script Editor for the
UltraCombo box. I HOPE this is the code you are referring to . (I am still
trying to figure out how everything fits together.)
using System;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using System.ComponentModel;
using Epicor.Mfg.UI;
using Epicor.Mfg.UI.FrameWork;
using Epicor.Mfg.UI.ExtendedProps;
using Epicor.Mfg.UI.FormFunctions;
using Epicor.Mfg.UI.Customization;
using Epicor.Mfg.UI.Adapters;
using Epicor.Mfg.UI.Searches;
using Epicor.Mfg.BO;
public static class Script
// ** Wizard Insert Location - Do Not Remove 'Begin/End
Wizard Added Module Level Variables' Comments! **
public static void InitializeCustomCode()
// ** Wizard Insert Location - Do not delete
'Begin/End Wizard Added Variable Initialization' lines **
// Begin Wizard Added Variable
Initialization
public static void DestroyCustomCode()
'Begin/End Wizard Added Object Disposal' lines **
// Begin Custom Code Disposal
// End Custom Code Disposal
private static void SearchOnSalesRepAdapterFillDropDown()
// Wizard Generated Search Method
// You will need to call this method from
another method in custom code
// For example, [Form]_Load or
[Button]_Click
bool recSelected;
if (recSelected)
// Set EpiUltraCombo
Properties
epiUltraComboC1.ValueMember
= "SalesRepCode";
epiUltraComboC1.DataSource =
dsSalesRepAdapter;
epiUltraComboC1.DisplayMember = "Name";
string[] fields = new
string[] {
"Name"};
epiUltraComboC1.SetColumnFilter(fields);
private static void PartForm_Load(object sender, EventArgs
args)
// Add Event Handler Code
SearchOnSalesRepAdapterFillDropDown();
Thanks for responding.
Mike
jckinneman
Sent: Wednesday, December 26, 2012 4:12 PM
Jim Kinneman
> 9.04.507a
use the whereclause to limit the records returned.
whereclause = "RoleCode begins 'Eng'"; // not 100% sure that 'begins' is the correct qualifier
Jim Kinneman
> using System;
> using System.Data;
> // Begin Wizard Added Module Level Variables **
> // End Wizard Added Module Level Variables **
> // Add Custom Module Level Variables Here **
> Initialization
> // End Wizard Added Variable Initialization
> // Begin Wizard Added Custom Method Calls
> // End Wizard Added Custom Method Calls
> // Begin Wizard Added Object Disposal
> // End Wizard Added Object Disposal
> [Button]_Click
> bool recSelected;
> if (recSelected)
> Properties
> = "SalesRepCode";
> dsSalesRepAdapter;
> string[] {
> "Name"};
> args)
> Mike
> jckinneman
> Jim Kinneman
> "mike.numbers" <mnumbers@> wrote:
> > 9.04.507a
Hi Mike,
You're filling the combo with a query but the query condition (whereClause)
selection.
Mark W.
I changed -
To-
Invalid query: where Company = 'CIGNYS' and (RoleCode like 'Eng%') BY Name.
Mike
Mark Wonsil
Hi Mike,
selection.
Mark W.
Change % to *
> I changed -
> To-
> Mike
> Mark Wonsil
> Hi Mike,
> selection.
> Mark W.
