JobMtl.Direct indicates if the job material requirement is to be directly supplied from a linked PO (or other job).
JobProd.TargetJobNum & JobProd.TargetMtlSeq will reference materials made direct (not to stock) to supply another job's material requirement.
PORel.JobNum & JobSeq allows you to relate purchase direct PO releases to their source/requiring jobs.
Sent: Tuesday, August 11, 2009 11:12:18 AM
Subject: [Vantage] Link Between Job and Purchase Order
Â
I am attempting to create a Dashboard for tracking vendor nonconformances. I am actually still in the BAQ creation stage, however. I have pretty much discovered that in order for the BAQ to supply me with the correct data, I need a link established between the Nonconformance Entry, the Job, and the Purchase Order. What I am having trouble with is finding some kind of a link between the job and the purchase order. I have searched through all of the Job and PO tables without any luck. Does anyone know what table and field can be used to establish a link between the two?
Thanks.
Â
Thanks.
