Link Customer Part Numbers to Our Part Numbers?
Greg: Great idea, I'll have to think about incorporating that idea
Nick: Good point. I don't think our customers require this, but I
will have to be sure to look out for it. Thank you.
--- In vantage@yahoogroups.com, "nmtaylor1969" <n.taylor@...> wrote:
> You should be fine with it, but as always there is a catch that
might
> cause you some problems ( it has for us )...
> Our customers are very sensitive about revision levels, and
therefore
> we need to map our customers part and revision level directly to
our
> part and revision level. Out of the box Vantage cannot do this. It
> will map your customers part number ( and revision ) to your
CURRENT
> part revision only.
> As can be the case on so many occasions, Vantage gets you 90% of
the
> way there and then falls short.
> Good luck...
> Nick
> --- In vantage@yahoogroups.com, "pbriscoe10" <pbriscoe10@> wrote:
> > Thank you all for your responses. I will play around with the
> > Customer Part entry in Setup and then use these parts in my
order
> > line items (I see the customer part field).
> > I'm assuming MRP will pick these up and create jobs for them
under
> > our part number. I'll give it a shot. Thanks again!
> > Patrick
> > --- In vantage@yahoogroups.com, "Winter, Patrick" <pjw@> wrote:
> > > Sales order line items have customer part field for your 3
> > different
> > > customers which could all point to the same "manufactured
part"
> > which
> > > your employees would enter jobs for. This basic functionality
has
> > been
> > > in vantage since the first version I started working with. I'm
> > afraid to
> > > say was (version 2.6).
> > > Patrick Winter
> > > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]
On
> > Behalf
> > > Of pbriscoe10
> > > Sent: Tuesday, October 21, 2008 10:14 AM
> > > To: vantage@yahoogroups.com
> > > Subject: [Vantage] Link Customer Part Numbers to Our Part
Numbers?
> > > Hi,
> > > We have a situation where 3 of our customers order an
identical
> > part
> > > yet each has their own part number for this part. We also have
> our
> > > own part number for this part that we have created. However,
when
> > > ordering, they would like to put the order through under their
> own
> > > part number rather than ours.
> > > For example, our company has part# 123X
> > > -our three customers call this part 123A, 123B, and 123C
> > > respectively.
> > > Is there a way to create an order for the customer part number
> > 123A
> > > yet have Vantage tell our job to create part 123X.
> > > Basically what we are looking for is a way to have customer
part
> > > numbers point to our own part numbers so that our employees
(who
> > are
> > > familiar with our part numbers) recognize the part they are
> > creating.
> > > Any help is appreciated. Thank you!
> > > This e-mail and any attachments may contain confidential and
> > > privileged information. If you are not the intended recipient,
> > > please notify the sender immediately by return e-mail, delete
this
> > > e-mail and destroy any copies. Any dissemination or use of this
> > > information by a person other than the intended recipient is
> > > unauthorized and may be illegal.
Hi,
We have a situation where 3 of our customers order an identical part
yet each has their own part number for this part. We also have our
own part number for this part that we have created. However, when
ordering, they would like to put the order through under their own
respectively.
Is there a way to create an order for the cutomer part number 123A
Basically what we are looking for is a way to have cutomer part
numbers point to our own part numbers so that our employees (who are
familiar with our part numbers) recognize the part they are creating.
You could set up each individual customer part number as a top level and
bring your part number in as a component.
_____
pbriscoe10
Subject: [Vantage] Link Customer Part Numbers to Our Part Numbers?
Hi,
respectively.
You should already have the functionality to do this...
Check out the "customer part" facility. Its within the "Sales : Order
Management : Setup" folder. ( At least in 8.03.305 anyway )
This should do most of what you need...
Nick
--- In vantage@yahoogroups.com, "pbriscoe10" <pbriscoe10@...> wrote:
> Hi,
part
> respectively.
are
creating.
Have you tried setting the Parts up under Customer Part number?
pbriscoe10
Sent: Tuesday, October 21, 2008 11:14 AM
Hi,
respectively.
Sales order line items have customer part field for your 3 different
customers which could all point to the same "manufactured part" which
your employees would enter jobs for. This basic functionality has been
in vantage since the first version I started working with. I'm afraid to
Patrick Winter
Of pbriscoe10
Hi,
respectively.
Is there a way to create an order for the customer part number 123A
Basically what we are looking for is a way to have customer part
please notify the sender immediately by return e-mail, delete this
Customer Part entry in Setup and then use these parts in my order
I'm assuming MRP will pick these up and create jobs for them under
Patrick
different
which
been
afraid to
> Patrick Winter
Behalf
> Of pbriscoe10
> Hi,
part
> respectively.
123A
are
creating.
In V6.0 you have the opportunity to add a Customer Part Number to
your Part Number on each Sales Order Line. We use the process
regularly and it works well. Use care however as once you generate a
(customer – your number pair) some fields will auto fill the next
time you do either a quote or sales order.
> Hi,
part
> respectively.
are
creating.
Thanks for the tip, apt.
I have created a test order with a customer part and ran the MRP,
which created an unfirm job with my company's part number. It seems
to be working smoothly. This is fantastic; thanks everyone for the
speedy replies :).
Patrick
generate a
> > Hi,
> part
our
when
own
> > respectively.
123A
> are
> creating.
I was wondering... is there an easy way to view all customer parts?
They don't show up in a Part search (understandibly because they are
not our parts) nor do they show up in the Customer Part setup. In
the Customer Part setup I can only create new parts, not view
previously created ones. I can view customer parts within a sales
order when I add a line, but this isn't very convenient if I just
want to see which customer parts we have for a given customer. I'm
sure I'm just not looking in the right places.
Thank you.
seems
> speedy replies :).
> Patrick
to
> generate a
next
> > > Hi,
identical
> > part
> our
> when
> own
> > > respectively.
> 123A
part
(who
> > are
> > creating.
V8.03.405a Sales Management - Order Management - Setup - Customer Part
Clicking the binoculars at top of screen opens search window that
shows all ......
are
> Thank you.
> seems
the
> > speedy replies :).
> > Patrick
> to
> > generate a
> next
wrote:
> > > > Hi,
> identical
> > > part
have
> > our
> > when
their
> > own
> > > > respectively.
> > 123A
> part
> (who
> > > are
> > > creating.
Yes, create a BAQ using the Part and the CustXPrt tables.
In your BAQ, establish the relationships of Part.Company =
CustXPrt.Company and Part.PartNum = Part.CustXPrt.
You may then use that BAQ in a BAQ Search in order to search various
maintenance modules and trackers by Customer Part Number instead of
your own Part Number.
Or you can use that BAQ in the BAQ Report designer. Then, if you
wish, you can put a cross-reference list report on the Vantage menu
for your users.
Lynn
are
> Thank you.
> seems
the
> > speedy replies :).
> > Patrick
> to
> > generate a
> next
wrote:
> > > > Hi,
> identical
> > > part
have
> > our
> > when
their
> > own
> > > > respectively.
> > 123A
> part
> (who
> > > are
> > > creating.
Oh, my. How could I miss the binoculars?! Thanks.
Lynn, that is a nice way to customize it. I'll look into that as
well.
Thank you.
various
of
menu
> for your users.
> Lynn
parts?
> are
In
sales
just
I'm
> > Thank you.
MRP,
> > seems
> the
> > > speedy replies :).
> > > Patrick
Number
> > to
process
> > > generate a
> > next
> wrote:
> > > > > Hi,
> > identical
> > > > part
> have
> > > our
However,
> > > when
> their
> > > own
> > > > > respectively.
number
> > > 123A
> > part
employees
> > (who
> > > > are
are
> > > > creating.
Order Tracker or Order Entry, sort by customer part
Patrick Winter
Of pbriscoe10
Sent: Tuesday, October 21, 2008 12:48 PM
Subject: [Vantage] Re: Link Customer Part Numbers to Our Part Numbers?
Thank you.
seems
> speedy replies :).
> Patrick
to
> generate a
> > (customer - your number pair) some fields will auto fill the
next
> > > Hi,
identical
> > part
> our
> when
> own
> > > respectively.
> 123A
part
(who
> > are
> > creating.
On thing I did was to put (bury) the customer part number ont the second
(third, fourth, etc.) line of the part description. That way if you are
in part tracker, you can put a customer part number in the "Where Part
Description Contains" box and it will find the part. It also comes in
handy when the customer changes their part number when they make a
revision change. Lots of automotive customers like to do this (eg:
197566C1 changes to 197566C2 when they change from revision a to
revision b).
I still use the customer part number field on the sales order of course
as well as in customer specific price lists.
Of pbriscoe10
Thank you.
seems
> speedy replies :).
> Patrick
to
> generate a
next
> > > Hi,
identical
> > part
> our
> when
> own
> > > respectively.
> 123A
part
(who
> > are
> > creating.
You should be fine with it, but as always there is a catch that might
Our customers are very sensitive about revision levels, and therefore
we need to map our customers part and revision level directly to our
will map your customers part number ( and revision ) to your CURRENT
part revision only.
As can be the case on so many occasions, Vantage gets you 90% of the
Good luck...
Nick
> Patrick
> different
> which
> been
> afraid to
> > Patrick Winter
> Behalf
> > Of pbriscoe10
> > Hi,
> part
our
own
> > respectively.
> 123A
> are
> creating.
