Link progress tables in access
Thank you
h--- In vantage@yahoogroups.com, jeremyrleonard@a... wrote:
> When linking the table, you need to select the little checkbox in the
right
> hand corner that says "Save Password".
> You will also need to run Epicors ODBC kit to setup ODBC before you
try to
> link the tables.
> HTH
> Jeremy
Is it possible to link tables from vantage to access?
I tries my self , i was able to see the tables via odbc but it gives me
authorization error when i would like to view entries.
When linking the table, you need to select the little checkbox in the right
You will also need to run Epicors ODBC kit to setup ODBC before you try to
link the tables.
HTH
Jeremy
