Linux Data Terminal
I probably ought to just can the idea seeing how we are going to
upgrade to Vantage 8 shortly, then I'll have to reinvent my data
terminal again. Thanks.
--- In vantage@yahoogroups.com, "Peter" <peter.paasch@a...> wrote:
> Had 5.1 working, but was extremely slow. Tried tweaks but just
> didn't work well. Wine worked for other apps well, but Vantage
> wasn't one of them. I don't remember the details, but it took a lot
> of screwing around to get Vantage working.
> --- In vantage@yahoogroups.com, "brentferland" <brentferland@y...>
> wrote:
> > I believe that the MFG file is actually a script run by progress
> > executable, so for it to run in Wine I'm guessing I have to convert
> > the MFG file into a dos command with the appropriate switches. But
> I
> > could be barking up the wriong tree any idea?
> > --- In vantage@yahoogroups.com, "Edward F. Fox, Jr." <efox@m...>
> wrote:
> > > www.winehq.org
> > > -----Original Message-----
> > > From: Edward F. Fox, Jr. [mailto:efox@m...]
> > > Sent: Monday, September 20, 2004 4:12 PM
> > > To: vantage@yahoogroups.com
> > > Subject: RE: [Vantage] Re: Linux Data Terminal
> > > You can try wine first, but I would run vcopydll under wine first
> > and maybe
> > > even edit the config to use the dll's that Vantage wants.
> > > You need to run the .exe file under wine and reference the .mfg
> file. I
> > > forget the exact syntax. Check the wine documentation at
> www.wine.org,
> > > there may be a hint there.
> > > From: brentferland [mailto:brentferland@y...]
> > > Sent: Monday, September 20, 2004 3:38 PM
> > > Subject: [Vantage] Re: Linux Data Terminal
> > > That is about where I was at trying to run the .MFG file. Is
> cross over
> > > absolutley needed, or will standard Wine work all right?
> wrote:
> > > > I did it with some help from Adam Ellis who is on the list.
> > > > Basically you need Crossover Office from Codeweavers,
> > > www.codeweavers.com.
> > > > This is a commercial version of Wine and tweaked to run MS
> Office
> > > and other
> > > > prominent windows apps.
> > > > You cannot call the .mfg file directly either. This is the part
> > > Adam helped
> > > > me with.
> > > > My experience was that Vantage ran too slow.
> > > > Sent: Monday, September 20, 2004 3:03 PM
> > > > Subject: [Vantage] Linux Data Terminal
> > > > Has anyone successfully installed vantage on a Linux
> workstation? I
> > > have
> > > > gotten it as far as getting the client installation to run.
> But I
> > > can not
> > > > seem to run the actual client. Of course I realize I may be
> out in
> > > > left field trying to make this work, but somebody has had to
> have
> > > > tried this before.
> > > > Useful links for the Yahoo!Groups Vantage Board are: ( Note:
> You
> > > must have
> > > > already linked your email address to a yahoo id to enable
> access. )
> > > > (1) To access the Files Section of our Yahoo!Group for Report
> > > Builder and
> > > > Crystal Reports and other 'goodies', please goto:
> > > > http://groups.yahoo.com/group/vantage/files/.
> > > > (2) To search through old msg's goto:
> > > > http://groups.yahoo.com/group/vantage/messages
> > > > (3) To view links to Vendors that provide Vantage services goto:
> > > > http://groups.yahoo.com/group/vantage/links
> > > > Yahoo! Groups Links
> > > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You
> > must have
> access. )
> > Builder and
> > > Yahoo! Groups Links
> > must have
> access. )
> > Builder and
> > > Yahoo! Groups Links
Has anyone successfully installed vantage on a Linux workstation? I
have gotten it as far as getting the client installation to run. But
I can not seem to run the actual client. Of course I realize I may be
out in left field trying to make this work, but somebody has had to
have tried this before.
Basically you need Crossover Office from Codeweavers, www.codeweavers.com.
This is a commercial version of Wine and tweaked to run MS Office and other
You cannot call the .mfg file directly either. This is the part Adam helped
me with.
Has anyone successfully installed vantage on a Linux workstation? I have
gotten it as far as getting the client installation to run. But I can not
seem to run the actual client. Of course I realize I may be out in left
field trying to make this work, but somebody has had to have tried this
before.
Yahoo! Groups Links
That is about where I was at trying to run the .MFG file. Is cross
over absolutley needed, or will standard Wine work all right?
and other
Adam helped
> me with.
have
can not
> before.
must have
Builder and
> Yahoo! Groups Links
You can try wine first, but I would run vcopydll under wine first and maybe
You need to run the .exe file under wine and reference the .mfg file. I
forget the exact syntax. Check the wine documentation at www.wine.org,
That is about where I was at trying to run the .MFG file. Is cross over
and other
Adam helped
> me with.
have
can not
> left field trying to make this work, but somebody has had to have
> tried this before.
must have
Builder and
> Yahoo! Groups Links
Yahoo! Groups Links
www.winehq.org
and other
Adam helped
> me with.
have
can not
> tried this before.
must have
Builder and
> Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
the MFG file into a dos command with the appropriate switches. But I
> www.winehq.org
and maybe
> and other
> Adam helped
> > me with.
> have
> can not
> > tried this before.
> must have
> Builder and
> > Yahoo! Groups Links
must have
Builder and
> Yahoo! Groups Links
must have
Builder and
> Yahoo! Groups Links
I
wrote:
> > www.winehq.org
> and maybe
file. I
www.wine.org,
cross over
Office
> > and other
> > Adam helped
> > > me with.
workstation? I
> > have
But I
> > can not
out in
have
> > > tried this before.
You
> > must have
access. )
> > Builder and
> > > Yahoo! Groups Links
> must have
access. )
> Builder and
> > Yahoo! Groups Links
> must have
access. )
> Builder and
> > Yahoo! Groups Links
