skearney
(Shannon Kearney)
July 23, 2019, 2:23pm
1
Does anybody have any information on how I can use the Data View List Changed event? I want to have a grid refresh when a Data View List has an item deleted or added. I just don’t understand how the coding of that works.
private static void Attribut_DataView_ListChanged(object sender, ListChangedEventArgs args)
// Attribut_DataView[0]["FieldName"]
// args.ListChangedType, args.NewIndex, args.OldIndex
// ListChangedType.ItemAdded, ListChangedType.ItemChanged, ListChangedType.ItemDeleted, ListChangedType.ItemMoved, ListChangedType.Reset
// Add Event Handler Code
It tells you in those comments what properties and things are available to you. Pretty self explanatory
IE: Types of changes, and how to access fields and data…
What are you not understanding?
skearney
(Shannon Kearney)
July 23, 2019, 2:31pm
3
Well when you put it so nicely lol. I have never used this before and I just didn’t know how to write this code.
skearney
(Shannon Kearney)
July 23, 2019, 2:32pm
4
Nevermind, I found some coding examples elsewhere.
sorry, just trying to understand what you were confused about and gauging what you had already tried #TeachAManToFish (or a woman).
Come back and share what you found those so that next time someone else can benefit #SearchIsYourFriend
Banderson
(Brandon Anderson)
July 23, 2019, 2:36pm
6
Here is some reading on event handling that will help with some basics of what’s going on here. It will make Epicors comments make more sense.
skearney
(Shannon Kearney)
July 23, 2019, 3:29pm
7
I ended up using this and it worked
private static void Customer_AfterFieldChange(object sender, DataColumnChangeEventArgs args)
// args.Row["FieldName"]
// args.Column, args.ProposedValue, args.Row
switch (args.Column.ColumnName)
case "AttrCodeList":
//MessageBox.Show("Attribute Code List Modified");
oTrans.Update();
badcredit();
break;
