List view drop down
I asked support in regards to this. The answer is the combobox in a listgrid is hidden and in the same group box as the listgrid (the combobox I was looking for was cboMiscCodeBound). Select this combobox, and you can set the autowidth option to manual and set the size of Col1ManualWidth.
--- In vantage@yahoogroups.com, Robert Brown <robertb_versa@...> wrote:
> If you're referring to the 1st column labeled ChargeID (application dataview OHOrderMisc.MiscCode, real 'like' table MiscChrg.MisCode) - No. Don't enter a Mask. (Sorry... Thought you were referring to charge itself - direct entry with no predefined code)
> The MiscCode itself is a 4 character field - but the native control has been mucked around with by Epicor to display each available MisCode's description in the pull down (which can be 30 characters - far exceeding the width of the Epicor customized pulldown window width). Epicor did this with many of these types of native ultragrid controls (why? - Only they know as it is a pain in the neck.)
> Just to rule out a simple fix, you can try reducing the font size in the control's properties window - but I doubt that pulldown will be affected (and if it is, certainly not enough to squeeze a 30 char max description into what looks like a 12-15 char pulldown).
> If your ambitious (and I'm not when it comes to this stuff), you can go into the custom object explorer and try and figure out which property for epiultragrids might be the key to changing the drop down width.
> I would try hideing the native ultragrid (and slide it off form for good measure so it doesn't 'bleed through' as often happens) and replace it with your own epiultragrid (linking it to the same application dataview OHOrderMisc).
> You should then find the MiscCode column actually displays the 4 char code (instead of the description). The pull downwidth problem should go away as well (and users can select fromthe description column).
> This doesn't always work. Sometimes Epcior has screwed around so much with the native control (hardcoding BO methods to it in ways we cannot access) that replacing with a std epiultragrid simply won't work.
> In less time than we've spent on these emails though, you can try both changing font size (native control) and replacing with your own epiultrgrid control.
> OR - you can shorten your descriptions so they FIT within the native control's pull down width.
> If none of that works and you simply must fix it, call support. They might be able to tell you what vb syntax to use to change the drop down width on this particular control (likely after checking with programming as they almost assuredly won't know).
> Good luck.
> Rob
> Â
> From: jed.sitzman <jed.sitzman@...>
> To: vantage@yahoogroups.com
> Sent: Wednesday, May 20, 2009 6:16:14 PM
> Subject: [Vantage] Re: List view drop down
> There is nothing in the Format and Mask Input properties. It is a character field. Should I put something in here?
> The width of the grid column is fine, it's just the drop down width isn't wide enough.
> --- In vantage@yahoogroups .com, Robert Brown <robertb_versa@ ...> wrote:
> > In the customization editor, click on your grid. Verify that the column properties "Format" and "Mask Input" aren't causing your truncation of the specific column that is vexing you. (Mask Input would be my 1st suspect.)
> > As for permanently changing the actual width of your grid columns, open the app and drag/drop them to the desired sequence and width of each. DON'T SAVE THIS AS A LAYOUT PERSONALIZATION. Immediately go into customization and save the customization as-is (with your grid layout & column width changes).
> > Those grid layout & width changes are now the defualt for all who are menu enabled to use your customization.
> > Rob
> > Â
> > ____________ _________ _________ __
> > From: jed.sitzman <jed.sitzman@ ...>
> > To: vantage@yahoogroups .com
> > Sent: Wednesday, May 20, 2009 9:37:09 AM
> > Thanks for the help, but this is a List view (EpiUltraGrid) , and I only can get to the properties of the EpiUltraGrid control. I can't edit the combobox that is displayed in the grid. It is not even shown in customization mode.
> > --- In vantage@yahoogroups .com, "Sean McDaniel" <smcdanie@ .> wrote:
> > > In customization, click on the control.
> > > In the properties, about mid-way down you will see the following properties
> > > AutoWidth
> > > AutoWidthOption
> > > Col1ManualWidth
> > > Col2ManualWidth
> > > Col3ManualWidth
> > > Col4ManualWidth
> > > By changing these you can control expand the display area when you click on
> > > the drop-down
> > > From: vantage@yahoogroups .com [mailto:vantage@ yahoogroups .com] On Behalf Of
> > > Robert Brown
> > > Sent: Tuesday, May 19, 2009 11:30 PM
> > > Subject: Re: [Vantage] List view drop down
> > > I assume by 'expanding the column width' you mean you went into
> > > customization mode and actual increased the horizontal width/size of the
> > > native drop down control.
> > > Click on the control in customization mode and look at its properties. See
> > > if they've put a display mask in place that might be causing the visual
> > > truncation. (Example ###.## - try increasing to ###,###.##).
> > > Some native controls are flaky (buggy is a better word) & do have this type
> > > problem. (Call support to see if this is the case for your version.) You
> > > could also try replacing the native control (slide it off form and make it
> > > invisible) with your own control where you should have total control over
> > > width.
> > > Rob
> > > From: jed.sitzman <jed.sitzman@ ... <mailto:jed. sitzman%40gmail. com> >
> > > To: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
> > > Sent: Tuesday, May 19, 2009 5:52:06 PM
> > > Subject: [Vantage] List view drop down
> > > Is it possible to increase the width of a drop down on a list view (Sales
> > > Order Entry...Header. ..Order MiscCharges) . Even when expanding the column
> > > width, the drop down width does not increase.
Is it possible to increase the width of a drop down on a list view (Sales Order Entry...Header...Order MiscCharges). Even when expanding the column width, the drop down width does not increase.
I assume by 'expanding the column width' you mean you went into customization mode and actual increased the horizontal width/size of the native drop down control.
Click on the control in customization mode and look at its properties. See if they've put a display mask in place that might be causing the visual truncation. (Example ###.## - try increasing to ###,###.##).
Some native controls are flaky (buggy is a better word) & do have this type problem. (Call support to see if this is the case for your version.) You could also try replacing the native control (slide it off form and make it invisible) with your own control where you should have total control over width.
Rob
Is it possible to increase the width of a drop down on a list view (Sales Order Entry...Header. ..Order MiscCharges) . Even when expanding the column width, the drop down width does not increase.
AutoWidth
AutoWidthOption
Col1ManualWidth
Col2ManualWidth
Col3ManualWidth
Col4ManualWidth
the drop-down
Robert Brown
width.
Rob
From: jed.sitzman <jed.sitzman@... <mailto:jed.sitzman%40gmail.com> >
Thanks for the help, but this is a List view (EpiUltraGrid), and I only can get to the properties of the EpiUltraGrid control. I can't edit the combobox that is displayed in the grid. It is not even shown in customization mode.
> AutoWidth
> AutoWidthOption
> Col1ManualWidth
> Col2ManualWidth
> Col3ManualWidth
> Col4ManualWidth
> the drop-down
> Robert Brown
> width.
> Rob
Rob
Â
> AutoWidth
> AutoWidthOption
> Col1ManualWidth
> Col2ManualWidth
> Col3ManualWidth
> Col4ManualWidth
> the drop-down
> From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf Of
> Robert Brown
> width.
> Rob
> Rob
> Â
> > AutoWidth
> > AutoWidthOption
> > Col1ManualWidth
> > Col2ManualWidth
> > Col3ManualWidth
> > Col4ManualWidth
> > the drop-down
> > Robert Brown
> > width.
> > Rob
Good luck.
Rob
Â
> Rob
> Â
> > AutoWidth
> > AutoWidthOption
> > Col1ManualWidth
> > Col2ManualWidth
> > Col3ManualWidth
> > Col4ManualWidth
> > the drop-down
> > Robert Brown
> > width.
> > Rob
