Load Multiple Parts into TimePhase
Is there a way to load multiple parts into Epicor - so i can click on each one (on the left side of the screen) and have the display/date change accordingly in TimePhase?
In classic, you do your query (standard, BAQ, Advanced, Data Tags) and multi-select the parts you want to see and press OK.
In Kinetic UI, do the same search (multi-select and OK) then click on the “>” in the Crumb Bar to move from part to part
Thank you…will attempt to do in BAQ. Appreciate the response. Didn’t know I could select multiple at the same time.
