Lock Table overflow
in Ver 4 you need to adjust the 'startup.pf' file in the progress bin
folder, I usually have it set for 10000, but recently I had to put it
up for our controler so I temporarly raised it to 20,000 and he was
able to finish up with no problems.
--- In vantage@y..., william <william@p...> wrote:
> A value of 8192 makes no sense for the lock table. -L is the number
of
> slots in the record locking table. It would normally be some round
> number like 2000 or 3500. However, each slot takes only 18 bytes of
> memory, and there is no measurable performance penalty for making it
> large, so try setting the number higher. Try 10,000. if that does
not
> work go to 15,000, and so on until you find a value that works. I
have
> run systems with values as high as 50,000 with out problem. Remember
> that you must stop, and restart the server for the change to take
> effect.
> HTH
> srini_majety@y... wrote:
> > HI,
> > Recently we moved to Vantage5.0 and are facing this problem with
> > sql92 odbc. It says 'Lock Table overflow, increase -L on the
server'.
> > Support says it should be at 8192 in the PExplorer settings.
> > Anybody has a solution for this ??
> > Thanks
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You
must have already linked your email address to a yahoo id to enable
access. )
> > (1) To access the Files Section of our Yahoo!Group for Report
Builder and Crystal Reports and other 'goodies', please goto:
> > (3) To view links to Vendors that provide Vantage services goto:
> > Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
> Specialists in Progress Databases and Software since 1986
> William E. Colls william@p...
> PROComputer Systems Tel 613 591 0079
> 67 Willow Glen Dr. Fax 613 591 3924
> Kanata Ontario Canada www.procomsys.com
> K2M 1T1
HI,
sql92 odbc. It says 'Lock Table overflow, increase -L on the server'.
A value of 8192 makes no sense for the lock table. -L is the number of
large, so try setting the number higher. Try 10,000. if that does not
work go to 15,000, and so on until you find a value that works. I have
effect.
HTH
srini_majety@... wrote:
> HI,
> Thanks
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.
> (2) To search through old msg's goto: http://groups.yahoo.com/group/vantage/messages
> (3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/links
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
William E. Colls william@...
K2M 1T1
