ckrusen
(Calvin Krusen)
May 13, 2020, 6:53pm
1
I made a customization that has a BeforeToolEvent. But there’s an error in my event handler, which is preventing me from entering customization mode.
I can select the customization just fine, but when it loads, I get:
edvQuoteHed.dataView[edvQuoteHed.Row][“QuoteComment”]
I clear that, and the blank form loads.
Upon selecting Tools -> Customization I get the “Index-1 is either negative …” error. And the Customization window never appears.
I’ve even tried loading a record before trying to enter Customization mode, but the same thing happens.
I know what the error in my customization is. I just can’t get to it to fix it.
Any thoughts on how to get in?
bordway
(Bruce Ordway)
May 13, 2020, 7:05pm
2
I have accessed some problem forms thru Customization Maintenance in the past.
Via menu items might let you into things when the form doesn’t want to load.
…your mileage may vary
ckrusen
(Calvin Krusen)
May 13, 2020, 7:11pm
3
Hadn’t thought about Customization Maint.
I can Export it from Cust Maint. Then I should be able to edit the XML, and then import it.
I’ll give that a try.
EDIT
That worked!
GaryWarn
(Gary Warn)
May 14, 2020, 3:05pm
4
FYI you didn’t need to export and re-import… you could have gone to the ‘Actions -> Show Custom Data’ menu and then on the displayed dialog box used the ‘Custom Code’ tab to make changes to the code and saved it there.
bordway
(Bruce Ordway)
May 14, 2020, 3:53pm
5
Yeah, I know I didn’t immediately realize the actions in customization maintenance either.
Now that I know, it often comes in handy…
