Does anyone know if it’s possible to have MRP Jobs created by Forecast Entry automatically locked? When we run MRP and then Calculate/Global Scheduling, this picks up all the Forecasted jobs and runs them together on one or two start dates to get better job efficiency. This would be fine but we want to keep the Forecasted jobs separated per the Forecasted Date in Forecast Entry. The Forecast Window uses zero for Days Before and 30 for Days After. If I need to lock each MRP job kicked out before running the Global Scheduling process, I guess that’s what I’ll need to do but I’m wondering if there may be an easier way.
Hello,
Hoping you might be able to help me identify MRP created Jobs that were generated by Forecast Entry. Is there a flag/field somewhere that indicates the job was generated through Forecast Entry?
Thank you kindly,
Jeremy
