Do you have crystal runtime installed on the server?
--- In vantage@yahoogroups.com, Chris Thompson <chriselectrix@...> wrote:
> Hi All,
> I have installed Logicity on our server and have tried running an example.
> I get an error which says ... Could not load file or assembly
> 'CrystalDecisions.CrystalReports.Engine,Version=12.0.2000.0, culture=neutral.
> Crystal report designer isnt installed on the server. It is only installed on my
> local PC.
> Does it need to be installed on the server as well?
> I have tried the same example from my PC and it works fine.
> This is the full error ...
> See the end of this message for details on invoking
> just-in-time (JIT) debugging instead of this dialog box.
> ************** Exception Text **************
> System.IO.FileNotFoundException: Could not load file or assembly
> 'CrystalDecisions.CrystalReports.Engine, Version=12.0.2000.0, Culture=neutral,
> PublicKeyToken=692fbea5521e1304' or one of its dependencies. The system cannot
> find the file specified.
> File name: 'CrystalDecisions.CrystalReports.Engine, Version=12.0.2000.0,
> Culture=neutral, PublicKeyToken=692fbea5521e1304'
> Â Â at Logicity_Desktop.ViewerForm..ctor(Int32 recordNumber, Array actList, Array
> parmList, Array setList)
> Â Â at Logicity_Desktop.ProgressForm.processActionList(Object startAt)
> Â Â at Logicity_Desktop.ProgressForm.ProgressForm_Load(Object sender, EventArgs
> e)
> Â Â at System.Windows.Forms.Form.OnLoad(EventArgs e)
> Â Â at System.Windows.Forms.Form.OnCreateControl()
> Â Â at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
> Â Â at System.Windows.Forms.Control.CreateControl()
> Â Â at System.Windows.Forms.Control.WmShowWindow(Message& m)
> Â Â at System.Windows.Forms.Control.WndProc(Message& m)
> Â Â at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
> Â Â at System.Windows.Forms.ContainerControl.WndProc(Message& m)
> Â Â at System.Windows.Forms.Form.WmShowWindow(Message& m)
> Â Â at System.Windows.Forms.Form.WndProc(Message& m)
> Â Â at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
> Â Â at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
> Â Â at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr
> wparam, IntPtr lparam)
> WRN: Assembly binding logging is turned OFF.
> To enable assembly bind failure logging, set the registry value
> [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
> Note: There is some performance penalty associated with assembly bind failure
> logging.
> To turn this feature off, remove the registry value
> [HKLM\Software\Microsoft\Fusion!EnableLog].
> ************** Loaded Assemblies **************
> mscorlib
> Â Â Â Assembly Version: 2.0.0.0
> Â Â Â Win32 Version: 2.0.50727.3615 (GDR.050727-3600)
> Â Â Â CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
> Logicity Solution Builder
> Â Â Â Assembly Version: 1.6.24.0
> Â Â Â Win32 Version: 1.6.0.0
> Â Â Â CodeBase:
> file:///C:/Program%20Files/SaberLogic/Logicity/Logicity%20Solution%20Builder.exe
> Microsoft.VisualBasic
> Â Â Â Assembly Version: 8.0.0.0
> Â Â Â Win32 Version: 8.0.50727.3053 (netfxsp.050727-3000)
> Â Â Â CodeBase:
> file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
> System
> Â Â Â Win32 Version: 2.0.50727.3614 (GDR.050727-3600)
> Â Â Â CodeBase:
> file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
> Â Â Â Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
> Â Â Â CodeBase:
> file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
> System.Drawing
> Â Â Â CodeBase:
> file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
> System.Runtime.Remoting
> Â Â Â CodeBase:
> file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
> Logicity.Common
> Â Â Â Assembly Version: 1.6.0.0
> Â Â Â CodeBase: file:///C:/Program%20Files/SaberLogic/Logicity/Logicity.Common.DLL
> Logicity Desktop
> Â Â Â Assembly Version: 1.6.25.0
> Â Â Â CodeBase:
> file:///C:/Program%20Files/SaberLogic/Logicity/Logicity%20Desktop.EXE
> ************** JIT Debugging **************
> To enable just-in-time (JIT) debugging, the .config file for this
> application or computer (machine.config) must have the
> jitDebugging value set in the system.windows.forms section.
> The application must also be compiled with debugging
> enabled.
> For example:
> <configuration>
> Â Â Â <system.windows.forms jitDebugging="true" />
> </configuration>
> When JIT debugging is enabled, any unhandled exception
> will be sent to the JIT debugger registered on the computer
> rather than be handled by this dialog box.
> Thanks.
