Looking for an Example BPM to approve OrderDtl partnum change
Looking for an Example BPM to approve OrderDtl partnum change.
I can prevent it, or popup a message, but looking for a way to ask if ok to change or not.
BPMDataForm
Not sure what method this goes on, didn’t trace.
Create a pre-processing BPM on the method.
  • Add a condition block, and check if the field has changed from any to another.
  • On the yes side, connect a BPM Data Form block.
  • Use the designer to create a new form, and add another button. Name that No and rename OK to Yes. Make sure you fill out the title and your text.
    Leave the Yes value to 1111.
  • Add a code block, and do something like this. Widget should be similar.
if(callContextBpmData.ButtonValue != 1111) //Anything other than (Yes is "1111")
    var updatedRow = ds.OrderDtl.FirstOrDefault(x => x.Updated());
    //Remove the row, we don't need it.
    ds.OrderDtl.Remove(updatedRow);
    //Abort, fail silently, as you already gave them a choice.
   MarkCallCompleted();
   //Or just let it go through the bpm, the updated row is gone anyway.
