Lot Tracing In Vantage 8.03.305K
Yeb, make sure you test, verify the cost adjustments/balances. Ensure
that you that you will not be using lot costing/ if you are using it
presently.
--- In vantage@yahoogroups.com, "nmtaylor1969" <n.taylor@...> wrote:
> Thanks for that. I presume you are referring to any on-hand
balances
> in inventory ? I need to adjust the quantities out, change the lot
> traced flag, and then adjust the quantities back in again, right?
> --- In vantage@yahoogroups.com, "brychanwilliams"
> <brychanwilliams@> wrote:
> > Adjust the lot quantities to zero. Switch off lot
tracking/costing.
> > Set the cost to what ever method and unit cost. adjust quantities
> > back in. There could be a cost variance/amount sitting in cost
> > adjustments depending on the changes in cost.
> > --- In vantage@yahoogroups.com, "nmtaylor1969" <n.taylor@> wrote:
> > > Does anyone know a work-around for this please:-
> > > As part of the evolution of implementing Vantage we have
changed
> > our
> > > views regarding the lot tracing of certain parts ( ok, ok, some
> > idiot
> > > decided to lot trace fasteners, but that's another story! ).
> These
> > > parts have some lots already recorded against them, but in the
> > future
> > > we want to turn off the lot tracing capability.
> > > It appears we can't. So, once a single lot has been recorded
> > against
> > > the part, the part is lot traced for evermore... :o(
> > > Do I have to create new part numbers to get me out of this, or
is
> > there
> > > a clever trick I have missed ?
> > > Thanks in advance,
> > > Nick Taylor
As part of the evolution of implementing Vantage we have changed our
views regarding the lot tracing of certain parts ( ok, ok, some idiot
decided to lot trace fasteners, but that's another story! ). These
parts have some lots already recorded against them, but in the future
It appears we can't. So, once a single lot has been recorded against
Do I have to create new part numbers to get me out of this, or is there
Thanks in advance,
Nick Taylor
Adjust the lot quantities to zero. Switch off lot tracking/costing.
our
idiot
future
against
there
> Thanks in advance,
> Nick Taylor
Thanks for that. I presume you are referring to any on-hand balances
> our
> idiot
These
> future
> against
> there
> > Thanks in advance,
> > Nick Taylor
