I have had this report since 1997.
Patrick
Sent: Tuesday, June 26, 2001 1:04 PM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] Lot Tracker or is it a Part Lot Tracker
You could create a report that shows all the part numbers linked to a
specific lot number.
Sent: Tuesday, June 26, 2001 12:45 PM
To: Vantage User Group on Onelist (E-mail)
Subject: [Vantage] Lot Tracker or is it a Part Lot Tracker
The Lot Tracker first asks you for the part number then the lot number.
In my case I may have the same lot number under several parts.
Would any other companies benefit from say another tab in Lot Tracker where
you just enter the Lot and it shows where it was used regardless of part
number?
Detail Description of problem:
I purchase various diameters which are different part numbers in inventory.
A wire supplier may draw the same heat lot of wire to different diameters.
So I end up with the same lot number in inventory under several part numbers
all made from the same original supplier lot.
Patrick Winter
sSc Specialty Screw Corporation
Vantage 5.00.317, Progress 9.1a
Yahoo! Groups Sponsor
<http://rd.yahoo.com/M=202225.1433492.3029752.1269402/D=egroupmail/S=1700007
183:N/A=675622/*http://altfarm.mediaplex.com/ad/ck/1177-3936-1039-2?mpt=9935
77551> []
<http://us.adserver.yahoo.com/l?M=202225.1433492.3029752.1269402/D=egroupmai
l/S=1700007183:N/A=675622/rand=928502640>
To access the Files Section of our Yahoo!Group for Report Builder and
Crystal Reports and other 'goodies', please go to:
<http://groups.yahoo.com/group/vantage/files/.> Note: You must have
already linked your email address to a yahoo id to enable access.
Your use of Yahoo! Groups is subject to the Yahoo! Terms of
<http://docs.yahoo.com/info/terms/> Service.
http://groups.yahoo.com/group/vantage/files/. Note: You must have already
Patrick
number?
Patrick Winter
77551> []
