Lot Tracking
Does anyone have a procedure for lot tracking? We are on Progress .408 and have
been approached by a customer of medical equipment who requires us to lot track
all of the components for his assemblies. I have tried getting info from the
help desk and from my CAM, all to no avail. Time to go to the 'A-Team'. Any and
all help would be appreciated. Pitfalls, shortfalls in the software, bugs,
workarounds, etc all welcome!
-Karl
Is anyone using the lot tracking capability in Vantage and if so how
would you rate its functionality?
Paul H. Smith
Vantage 6.0
We use it and it works fine for us. The only problem we had was that once a lot of material was used up it left the lot number in the system. I wrote a procedure that deletes all unused lots. Makes it easier to find what you want.
Jeremy
Sent: Friday, April 02, 2004 2:17 PM
Subject: [Vantage] Lot Tracking
Paul H. Smith
Vantage 6.0
Yahoo! Groups Links
It works. It does everything we need it to.
Bob Bruton
Entek Corp.
Sent: Friday, April 02, 2004 1:17 PM
Paul H. Smith
Vantage 6.0
I have been using it since it first became available on version 2.7, works
great for me.
Patrick Winter
Is anyone using the lot tracking capability in Vantage and if so how would
Paul H. Smith
Vantage 6.0
Yahoo! Groups Links
Jeremy,
Any chance you could fire that off to me? Love to take a
look at that!
Thanks!
Lorne Rogers
Aria Consulting & Implementers Ltd.
Epicor Vista/Vantage Authorized Re-Seller and Consulting
<http://www.ariaconsulting.net/>
Add this card to your
<http://ariaconsulting.net/vcf/aria.vcf> OutlookT Contacts
Sent: Friday, April 02, 2004 1:13 PM
Subject: RE: [Vantage] Lot Tracking
Jeremy
if so how
Paul H. Smith
Vantage 6.0
Yahoo! Groups Links
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://rd.yahoo.com/SIG=12c43gm62/M=291630.4786521.5933964.
1261774/D=egroupweb/S=1705007183:HM/EXP=1081023212/A=2072415
/R=0/SIG=11thh7ako/*http://www.netflix.com/Default?mqso=6017
8432&partid=4786521> click here
<http://us.adserver.yahoo.com/l?M=291630.4786521.5933964.126
1774/D=egroupweb/S=:HM/A=2072415/rand=330148485>
_____
Yahoo! Groups Links
<mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscr
ibe>
* Your use of Yahoo! Groups is subject to the Yahoo!
Terms of Service <http://docs.yahoo.com/info/terms/> .
Sure,
Its in MSAccess.
You will need to rename the program LotClear.mdb.
Then relink the tables to Progress via an ODBC connection with the issolation level set to Read Committed.
That shoud do it. We have been running it for two years with no problem. Normally takes 3-10 min to run.
If you have any questions, feel free to call. 1317-398-6684
Jeremy
[mailto:lrogers@...]
Sent: Friday, April 02, 2004 3:51 PM
Jeremy,
look at that!
Thanks!
Lorne Rogers
Jeremy
if so how
Paul H. Smith
Vantage 6.0
Yahoo! Groups Links
ADVERTISEMENT
_____
Yahoo! Groups Links
ibe>
Yahoo! Groups Links
Vantage Expert(s)
We are looking into using Vantage Lot Tracking. The challenge we
have is that we need to use lot tracking for multi-level assemblies
(approximately 4 levels) where sub assemblies can be used on
different finished products. Each sub assembly has its own job
number. We do not see a good way to tie everything together. Does
anyone have any experience in this area?
Any help would be greatly appreciated.
Why not use projects?
Sent: Tuesday, February 22, 2005 2:49 PM
Vantage Expert(s)
Yahoo! Groups Links
a.. To visit your group on the web, go to:
b.. To unsubscribe from this group, send an email to:
c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.859 / Virus Database: 585 - Release Date: 2/14/2005
We track lots on every item in the house -- if it is manufactured, it is
stocked using the job number as the lot number, if it is purchased, it is
stocked using the PO number as the lot number. We have complete visibility
on what came from where, fifo, and what went where. We have quite a few
multi-level assemblies and it seems to work fine. Course, we may not be as
big as you are, we have one guy who handles raw materials and one inventory
person for everything else.
Hope this helps,
Lydia
Sent: Tuesday, February 22, 2005 12:49 PM
Vantage Expert(s)
Yahoo! Groups Links
We do basically the same as Lydia described, using the job number as the
lot number for manufacturing products, only our purchased materials get a
sequential 7 digit number.
In reality, we really do something slightly more complex than this, and I'm
not sure if it is a residual of another era, or if we really need it (what
Lydia describes will work for most people).
If you routinely issue more than one subassembly lot to a higher level job
and need to keep the subassembly lot numbers separate throughout the
manufacturing process--we do the following---keep adding the subassembly
jobs numbers as the lot numbers as below.
You can then see if Job X was used to Job A somewhere else.
Level Lot Number
Level 0 JobZ JobY JobX JobW
Level 1 JobY JobX JobW
Level 2 JobX JobW
Level 3 JobW
Level 0 JobA JobB JobX JobW
Level 1 JobB JobX JobW
Level 2 JobX JobW
Level 3 JobW
But regardless of how difficult you make it, lot tracking in Vantage works
well for us.
An example: A few months ago, one of our inspectors found a lot number
error on one of our subassembly part numbers, and I was able to easily
track down all 12,000 parts in 6 different top level assembly jobs with
several different finished good part numbers (thankfully none had shipped),
and repair the lot number.
Hope this helps more than it confuses :-)
Amy O'Malley
Synovis IS
Lino Lakes, MN
omall004@...
visibility
as
inventory
> Hope this helps,
> Lydia
> From: hollis55555 [mailto:heather@...]
> Vantage Expert(s)
Thanks for the idea. I will think about how this may help.
Lou, We also have the exact same situation and we have more like 50 items or more per job. I concur with you on the time consuming, manual entry problem that is prone to errors occasionally.Currently we are heat tracking in a legacy SQL Server based PC standalone system where we capture the supplier's lot and heat info and scan the certs with reference pointers to pull up in Adobe reader using the lot#, heat# reference. We generate our own Lot# within this system to enter into Vantage. I'm testing adding a UD field to add the heat# and the supplier provided lot# as well. We haven't used the backflushing mechanism yet since just about every part is lot/heat/serial number tracked.
RSN
----- Original Message ----
Sent: Thursday, June 28, 2007 9:17:17 AM
Subject: Re: [Vantage] Re: Lot Tracking
We are required to track the heat number of incoming steel for raw material and hardware.
We could have up to 30 items on a job to issue and all of them are currently lot tracked and could have multiple heat lot numbers. Very time consuming even with mass issue because of the multiple heat numbers per component.
What I would like to do is backflush the inventory when we report the picking operation complete, but currently can't bacause of lot tracking.
So our idea is to find some other way to track the supplier heat number. A UD field was one of our thoughts.
Michael McWilliams <mmcwilliams22@ yahoo.com> wrote:
Can you explain a little more about what info you are trying to
accomplish. You might be able to just use a UD table in Vantage
--- In vantage@yahoogroups .com, Lou Laird <loulrd@...> wrote:
> We currently lot track purchased parts and we are a make to order
company.
> Michael McWilliams <mmcwilliams22@ ...> wrote: --- In
vantage@yahoogroups .com, Lou Laird <loulrd@> wrote:
> Do you lot track both purchased & Manufactured Parts? Are you make
to
> Order?
> > Looking for any companies doing lot tracking outside of Vantage.
> > We current use Vantage lot tracking and want to stop in some
areas
> so we can backflush inventory and we are looking for alternative
> methods to track.
> > Be a PS3 game guru.
> > Get your game face on with the latest PS3 news and previews at
> Yahoo! Games.
> Ready for the edge of your seat? Check out tonight's top picks on
Yahoo! TV.
Choose the right car based on your needs. Check out Yahoo! Autos new Car Finder tool.
____________________________________________________________________________________
Be a better Globetrotter. Get better travel answers from someone who knows. Yahoo! Answers - Check it out.
http://answers.yahoo.com/dir/?link=list&sid=396545469
I'm curious. Whether it's in Vantage or an external tracking system, if
you have multiple heat numbers being issued to a single job how do you
trace the heat numbers to a specific finished part?
Mike Lowe
Corporate I.T. Manager
Connor Manufacturing Services
Direct: (949) 713-3328
Fax: (949) 666-5268
Cell: (949) 973-7621
Skype: Mike.Lowe
Email: MLowe@... <mailto:MLowe@...>
Web: www.connorms.com <http://www.connorms.com/>
Of RSN
Sent: Thursday, June 28, 2007 10:27 AM
RSN
From: Lou Laird <loulrd@... <mailto:loulrd%40yahoo.com> >
per component.
company.
to
> Order?
areas
> methods to track.
> > Be a PS3 game guru.
> Yahoo! Games.
Yahoo! TV.
Finder tool.
<http://answers.yahoo.com/dir/?link=list&sid=396545469>
This email has been scanned by the MessageLabs Email Security System.
For more information please visit http://www.messagelabs.com/email
I created one UDTable to hold the Raw Material Lots. In our case
every line is a new lot so I create a new record for every line. At
receipt time they put in the Heat and any other info for the lot,
and it copies that info to the UDTable. We use a report that prints
tags from the UDtable to use for labeling and scanning.
When they report production they scan the lot that they are using.
When they do that it creates a record In a second UD table that is a
unique record for the manufactured lot/serial whatever you want to
call it. In our case it is a bundle of items that need to be
identified as unique. That UD record holds the Job Number the
quanity and a bunch of other info as well as the lot
used to create it. When they pack a lot in shipping it goes out to
the second UDTable and Marks a checkbox and puts in the date it was
packed. It also puts the packing slip number on the Manufactured
Lot Record.
When we print our packing slip using crystal we pull all the heat
and chemistry info from the UD table by linking the Pack to the Tags
that shipped. The customer can see every item we shipped with what
heat/lot was used as well as the mechanical and chemical composition
of that heat.
All of our programs that deal with inventory make calls to the
UDtables to update various records or pull data if needed.
system, if
you
> Mike Lowe
> Fax: (949) 666-5268
> Skype: Mike.Lowe
Behalf
> Of RSN
manual
are heat
into
supplier
yet
> RSN
Very
numbers
> per component.
the
tracking.
number.
order
> company.
make
> to
> > Order?
Vantage.
> areas
> > methods to track.
> > > Be a PS3 game guru.
> > Yahoo! Games.
on
> Yahoo! TV.
new Car
> Finder tool.
who
_
System.
_
Mr. McWilliams,
How are you entering all of the Physical and Chemical properties into
Vantage? Are you just dumping the information into a text field, or
are you taking that information and verifying it against a material
specification? Also, are you required to have a serial number on your
shipping tags? We are currently implementing Vantage and are looking
for a way to use a serial number to track individual baskets of parts
shipped to our customer. The serial number would be a self
populating, unique, sequential number. Thanks for any information in
advance.
Eric
--- In vantage@yahoogroups.com, "Michael McWilliams"
> Lot Record.
> of that heat.
Right now they are in Numeric fields. Every receipt line is a
new "Lot" basically serial but not exactly. That number is generated
by getting the next number from a UD table & creating a
corresponding UD record. It then takes the numbers that you entered
and pushes them into the UD table. I am working on a verification
that will only allow you to enter if the properties are within
acceptable values.
We are required to have a "Bundle" number on our shipping tags.
Every bundle gets a unique number. Since you are creating baskets
of parts I do not belive that the Vantage serialization will work.
It wants you to give a uniqe number to every unit that is created.
I have a question about your creation of baskets. Do you use MES to
do this or will it be done in the office?
--- In vantage@yahoogroups.com, "Arnulfo Mora" <amora@...> wrote:
> Mr. McWilliams,
into
or
your
looking
parts
in
> advance.
> Eric
line. At
lot,
prints
using.
is a
to
to
was
Manufactured
> > Lot Record.
heat
Tags
what
composition
> > of that heat.
What we are currently planning is to use MES to report quantities in
the basket. When the operator finish a basket they will hit report
quantity in MES, print tag, and send it on to the next operation or to
shipping. For ASN's, we are required to have a unique number on each
shipment. With what we can currently tell, we will not be able to put
a unique number on the shipping tag for traceability. This is a
requirement for many automotive companies. This unique number is used
to track back to the exact time, date, steel coil, operator, etc. when
a customer calls in with a concern/rejection. We would use the serial
number for containment of all baskets created under a certain steel
tag number, after a certain number of hits, or any other items that
may be suspect. The unique number is the trigger for all
correspondence with our customer. In essence, we need to serialize
every container (basket), but not every part. If you have any
additional questions, please let me know.
Thanks in Advance,
Eric
> acceptable values.
> --- In vantage@yahoogroups.com, "Arnulfo Mora" <amora@> wrote:
> > Mr. McWilliams,
> into
> or
> your
> looking
> parts
> in
> > advance.
> > Eric
Each labor detail record has a unique number...maybe you can use that
field on the shipment somehow as your traceability.
Something to look at maybe....?????
M. Manasa Reddy
manasa@...
P: 630-806-2000
F: 630-806-2001
Of Arnulfo Mora
Sent: Tuesday, November 13, 2007 10:45 AM
Subject: [Vantage] Re: Lot Tracking
Thanks in Advance,
Eric
> acceptable values.
> > Mr. McWilliams,
> into
> or
> your
> looking
> parts
> in
> > advance.
> > Eric
Hi, I've been thinking about Lot Tracking in Vantage too.
Someone mentioned they use Job Number as lot number, let's say i have
a Job 000090 which runs for a month, during the course of the
production, I've received 2 different lot of the same materials, lot A
56,000 and lot B 44,000.
If I saved the finished good under Lot 000090, and 1 month down the
road the supplier called and said Lot A is problematic, seems like
I'll have to recall the entire batch of 000090?
How would we be able to best handle this then?
I was thinking of using 000090-1, 000090-2, 000090-3 and so on until
the last run.
Of course, there may be a possibility that a part of the job will be
taking in 2 lots of materials, but at least we would've kept it down
to a minimum, instead of recalling the entire batch of 100,000 in job
000090?
> M. Manasa Reddy
> manasa@...
> P: 630-806-2000
> F: 630-806-2001
> Of Arnulfo Mora
> Thanks in Advance,
> Eric
> > acceptable values.
> > > Mr. McWilliams,
> > into
> > or
> > your
> > looking
> > parts
> > in
> > > advance.
> > > Eric
