Make a field Read Only to all but certain Security Groups
Why not indeed? It would help if I looked properly at the options
available!! I never saw the "user does not belong..." condition.
Yours is a much simpler solution. Thanks.
Nigel.
--- In vantage@yahoogroups.com, "Ross Hughes" <ross.hughes@...> wrote:
> Why not just throw an exception error for the action with the
"raise an
> exception based on the designed template' approach instead of the
4GL code.
> This will stop the BO update and give you a message box (design
template)
> option.
> You can also add an AND to the conditions and insert a 'user DOES
NOT belong
> to group' condition as well.
> So:
> Condition 1: the ttOrderHed.TermsCode field has been changed from
any to
> any.
> AND
> Condition 2: 'user DOES NOT belong to SG002'
> Action: raise an exception based on the designed template. (insert
message
> box text in designed template).
> Another possibility.
> Ross
> -----Original Message-----
Behalf Of
> Nigel Kerley
> Sent: Wednesday, January 07, 2009 9:19 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Make a field Read Only to all but certain
Security
> Groups
> This has been asked before but I don't think there was a
satisfactory
> solution. I reckon the best way is by BPM. I have a need for this
as
> well, so I though I'd have a look at it now. Here's what I've come
up
> with:
> A pre-processing directive against the SalesOrder.Update BO.
> One condition: the ttOrderHed.TermsCode field has been changed from
> any to any.
> One action: execute the following 4GL code
> Code:
> Find first ttOrderHed where ttOrderHed.RowMod = 'A' or
> ttOrderHed.RowMod = 'U' NO-LOCK NO-ERROR.
> If available ttOrderHed then do:
> find UserFile where UserFile.DcdUserID = DCD-UserID no-lock.
> if INDEX(UserFile.GroupList, 'SG002') = 0 then do:
> {lib/PublishEx.i &ExMsg = "'You do not have permission to
> change this field.'" }
> {&THROW_PRIVATE}.
> end.
> end.
> "SG002" is the code for the security group of those allowed to
amend
> the field.
> It seems to work, but I haven't finished testing it yet.
> Nigel.
> --- In vantage@yahoogroups.com, "Calvin Krusen" <ckrusen@> wrote:
> > What's the 'Best' way to make a field default to R/O, but be R/W
to
> a
> > certain Security Group?
> > I need to make the Terms field on the Order Entry program be R/O
> for
> > all but a specific Security Group. I still need the terms field
to
> be
> > auto-populated by when a custeomer ID is entered, but don't want
OE
> > folks to be able to change it.
> > Should I go for a...
> > A) Customization (I've already did some in the OE program)
> > B) A BPM
> > C) Field Security
> > D) something entirely differant
> > Thanks
> > Calvin
must have
Builder and
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
What's the 'Best' way to make a field default to R/O, but be R/W to a
I need to make the Terms field on the Order Entry program be R/O for
all but a specific Security Group. I still need the terms field to be
auto-populated by when a custeomer ID is entered, but don't want OE
B) A BPM
C) Field Security
Calvin
This has been asked before but I don't think there was a satisfactory
solution. I reckon the best way is by BPM. I have a need for this as
well, so I though I'd have a look at it now. Here's what I've come up
with:
any to any.
Code:
{&THROW_PRIVATE}.
end.
end.
"SG002" is the code for the security group of those allowed to amend
the field.
Nigel.
a
for
be
> B) A BPM
> C) Field Security
> Thanks
> Calvin
Why not just throw an exception error for the action with the "raise an
exception based on the designed template' approach instead of the 4GL code.
This will stop the BO update and give you a message box (design template)
option.
You can also add an AND to the conditions and insert a 'user DOES NOT belong
So:
Condition 1: the ttOrderHed.TermsCode field has been changed from any to
any.
AND
Action: raise an exception based on the designed template. (insert message
Ross
Nigel Kerley
Subject: [Vantage] Re: Make a field Read Only to all but certain Security
Groups
with:
any to any.
Code:
{&THROW_PRIVATE}.
end.
end.
the field.
Nigel.
a
for
be
> B) A BPM
> C) Field Security
> Thanks
> Calvin
