I was able to discuss this with an Epicor Technical Consultant and
your answer was the one he gave. I hadn't thought about two separate
installs of Service Connect until we spoke, and now it makes much
more sense to me.
Thanks to everyone who weighed in on this issue.
Jim Pratt
more sense to me.
Jim Pratt
--- In vantage@yahoogroups.com, "Ned" <TechnoBabbly@...> wrote:
> You should be able to do this no problem.
> The best way to do this is with a completely seperate installation
of both
> Vantage and Service Connect in your sandbox/test environment.
> By doing this you are able to keep pretty much every setting the
same when
> you export and move the WorkFlow from one environment to the other.
This is
> also the best practice to avoid any potential cross contamination
of data
> between the databases.
> Since this is only needed for proof of concept and not performance,
you can
> use a lower end workstation machine instead of an actual server to
run
> these, or you can also use a virtual installation on something like
VMWare
> or MS's version of Virtual Server.
> From: "jmpratt7" <james.pratt@...>
> To: <vantage@yahoogroups.com>
> Sent: Tuesday, December 16, 2008 8:07 AM
> Subject: [Vantage] Managing Service Connect in a SOx controlled
environment
> > We are new to SC and need to setup SC so we can develop workflows
in an
> > existing sandbox environment, and once proven, promote to our
> > production environment.
> > Does anyone have experience with SC working in an environment like
> > this? As I have looked at the various levels of SC, it seems
that the
> > server:database that you work with are hard coded into various
elements
> > of the workflow. I am hoping to setup an arragement where we can
> > develop and then simply redirect to the production
server:database when
> > ready.
> > Does anyone have any thoughts on this?
> > Thanks,
> > Jim Pratt
> > Ameridrives
> > Vantage since 11/26/06
> > Vantage 8.03.404B since 9/12/08
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You
must
> > have already linked your email address to a yahoo id to enable
access. )
> > (1) To access the Files Section of our Yahoo!Group for Report
Builder and
> > Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.
> > http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
