Todd,
Hello, Yes I have seen that problem you're having. You might wanna try to
copy that dll file from an nt workstation to the computer you are having
problem with. That is one of the problems I came accross especially when an
employee try to use the data collection.
Marites Marlar
SPS Non-Ferrous
Las Vegas, NV 89118
(702) 262-9922 Ext. 118
(702) 262-9923 Fax
Sent: 28 September, 2000 05:56
To: Vantage List (E-mail)
Subject: [Vantage] Mapi32.dll
Yesterday I began receiving errors on two workstations. When clicking OK
from the issues to manufacturing window, the following error would occur:
"Could not load DLL procedure mapi32.dll. (3258)"
If you clicked OK to the error dialog it returned you to the Issues
screen.
I looked at the transaction history and it appears as though the
transaction
was successful. If I print the production detail report, the transaction
is
not there and if I view the inventory stock status, the item is still in
stock.
I did a find on the dll file and it produced no results. I then
re-installed
Vantage on that client but the error persisted. I fixed the error by
copying
the noted dll from a properly functioning machine and the problem has went
away.
My questions:
Has anyone else seen this?
What causes it?
Why the inconsistencies in my audit trail of the items the error occurred
on?
Thanks in advance
Todd Hofert
Spartan Graphics, Inc.
(616)887-8243
(Note: If this link does not work for you the first time you try it, go
to www.egroups.com, login and be sure to save your password, choose My
Groups, choose Vantage, then choose Files. If you save the password, the
link above will work the next time you try it.)
Marites Marlar
SPS Non-Ferrous
Las Vegas, NV 89118
(702) 262-9923 Fax
screen.
transaction
is
stock.
re-installed
copying
away.
My questions:
What causes it?
on?
Thanks in advance
Todd Hofert
(616)887-8243
