Mapped drives
thank you
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Thursday, June 02, 2005 1:42 PM
Subject: RE: [Vantage] MAPPED DRIVES
> Are you using a batch file for the client login? All of my users have a
> batch file that maps whatever drives I want them to have access to. It's
> very easy. Using Note Pad create your script use the following syntax to
> map your drives.
> @echo off
> net use \\rai_nt\panfront
> net use e: \\Raiw2k\Apps
> net use n: \\raiw2k\EPIC50
> net use q: \\Raiw2k\Share
> net use s: \\Raiw2k\Sales
> net use z: \\Raiw2k\Zfax
> net use O: \\Raiw2k\UPS
> Line 2 maps a shared printer
> Line 3 through 8 maps shared directories to the mapped drive letters "E"
> through "O"
> Save the note pad file to the following directory on your domain
controller
> C:\WINNT\SYSVOL\sysvol\RAI.com\scripts using a file name like
"login.bat"
> In the user profile go to the PROFILE tab and enter "login.bat" in the
LOGON
> SCRIPT: field. Every time the user logs in the script will map the
drives
> to his computer. This will work no matter what computer they login on.
> Shirley Graver
> Sys Admin
> Rubber Associates Inc.
> _____
Of
> Robert Christian
> Sent: Thursday, June 02, 2005 1:14 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] MAPPED DRIVES
> I am having a real problem with 1 xp pro machine. I map a drive under
admin
> and it does not show
> on the client side I have never had this problem before. Checked security
> seems aright. the mapped drive to vantage
> is fine this is a mapped drive I use for drawings therefore I cannot view
> them through vantage with autovue
> Any Ideas would be greatly appreciated thanks bob
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
have
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> <http://groups.yahoo.com/group/vantage/files/>
> _____
> Yahoo! Groups Links
> * To visit your group on the web, go to:
> * To unsubscribe from this group, send an email to:
> vantage-unsubscribe@yahoogroups.com
> <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
> <http://docs.yahoo.com/info/terms/> .
> Tracking #: 3A0422910ADB874F8F4927EB2442602113F7F2A9
> Yahoo! Groups Links
I am having a real problem with 1 xp pro machine. I map a drive under admin and it does not show
on the client side I have never had this problem before. Checked security seems aright. the mapped drive to vantage
is fine this is a mapped drive I use for drawings therefore I cannot view them through vantage with autovue
map your drives.
@echo off
through "O"
Save the note pad file to the following directory on your domain controller
C:\WINNT\SYSVOL\sysvol\RAI.com\scripts using a file name like "login.bat"
In the user profile go to the PROFILE tab and enter "login.bat" in the LOGON
SCRIPT: field. Every time the user logs in the script will map the drives
Shirley Graver
Sys Admin
_____
Robert Christian
_____
Yahoo! Groups Links
Mapped drives are by user not by machine. You have to log onto the pc as
that user and then map the drive or run a login script. You must also use the
/persisent:yes to keep the mapping after reboot.
HTH
Jeremy
Thank You
Sent: Thursday, June 02, 2005 1:50 PM
Subject: Re: [Vantage] MAPPED DRIVES
the
> HTH
> Jeremy
> Yahoo! Groups Links
