Personally, i would simplify the code above written by @hmwillett to do the read, and then NOT do a “foreach” since there is only line record to read. Something like this:
//NEW VERSION (old version below for reference)
var ttPOHed = ttPOHeader.FirstOrDefault();
if( ttPOHed != null ){
var poHed = Db.POHeader.With(LockHint.UpdLock).where(x=>
x.Company == Session.Company &&
x.PONum == ttPOHed.PONum).FirstOrDefault();
if (poHed != null) {
using(var scope = IceDataContext.CreateDefaultTransactionScope())
poHed.ApprovalStatus = "P";
Db.Validate();
scope.Complete();
//FOR REFERENCE: here is the OLD CODE:
var tt = ttPOHeader.FirstOrDefault();
if( tt != null )
int poNum = tt.PONum;
foreach(var po in (
from ph in Db.POHeader.With(LockHint.UpdLock)
where ph.Company == Session.CompanyID &&
ph.PONum == poNum
select ph))
if( po != null )
po.ApprovalStatus = "P";
Db.Validate();
scope.Complete();
Can we guarantee there is always just one record? It is of course on the PO Form,
but could this BO be called from another place with more than one record?
The way that this code was written, it first gets the SINGLE TT record, which only has ONE PO, so therefore there is only one po to read. Yes, there are other instances where there could be multiple values that need to be “foreached” but for this specific use case, there is only one.
