Ok - so this is likely an issue with Epicor but just in case someone has a solution.
My client is using Markup Codes by Part Class - however they are calculating using Profit not Markup. NOTE: THIS DOES NOT HAPPEN WHEN USING MARKUP
We added a Markup code with the predefined Markup Codes
Start the Quote
Do the normal stuff
We decide to change one of the markup/profit % in the Markup Tab to ANYTHING but what was there.
Go back to Worksheet and Refresh Worksheet. Suddenly the calculation % for material goes from a normal calculated percent to 99.99%!!! Doesn’t matter what we do after that it always does this.
Has anything seen this? I’ve never seen this before 10.2.600 (then again that is a pretty long list of "never seen before 10.2.600).
TIA,
John
