Mass Issue - Issue List
Simply by hiding all unecessary columns, changing the column order & making columns read-only (if not already) when not wanting entry done in them.
You may find you want a very limited column custom version for just your entry process (in case you use the same app in other ways).
--- On Fri, 2/6/09, bpbuechler <pbuechler@...> wrote:
Subject: [Vantage] Re: Mass Issue - Issue List
Date: Friday, February 6, 2009, 12:46 PM
Yes, the ultragid has one tab stop and appears to be predefined in
the code. We are on 8.03.405.
In the other ultragrids you have worked with, how did you change the
tab stop?
Patty Buechler
--- In vantage@yahoogroups .com, Robert Brown <robertb_versa@ ...>
wrote:
> Patty,
> Are you saying this ultragrid is different than (all) others I've
ever seen (we don't use Mass issue so not familiar with it... Haven't
looked at it since we were piloting) in that you can't set your
column order to optimal order for your process & also set any
extraneous potential entry fields to read only in the grid properties?
> (What version are you on?)
> Rob
> --- On Thu, 2/5/09, bpbuechler <pbuechler@. ..> wrote:
> From: bpbuechler <pbuechler@. ..>
> To: vantage@yahoogroups .com
> Date: Thursday, February 5, 2009, 3:16 PM
> Yes...the down arrow works.
> However, I have to tab six times just to get to the Issued Qty
column.
> Additionally, I am going to have them scan the qty from a job pick
> list (not key in); so the down arrow wouldn't work....
> Patty
> --- In vantage@yahoogroups .com, "bw2868bond" <bwalker@ > wrote:
> > Does the down arrow work in the grid?
> > --- In vantage@yahoogroups .com, "bpbuechler" <pbuechler@> wrote:
> > > Currently when you launch the Issues List tab, it defaults to
the
> > > Assembly Seq.
> > > We are attempting to change the Tab Stop of the default Ultra
> Grid.
> > > We want to change it to default to the Issued Qty box and then
> hit
> > > tab/enter to the next line Issued Qty box.
> > > If I am trying to mass issue (quick issue materials), I want to
> > enter
> > > qty <enter>, enter qty <enter>, enter qty <enter> click OK to
> close
> > the
> > > screen. Has anyone been able to do this?
> > > I have opened a call with Epicor and their intial reponse was
> > leaning
> > > towards another example of their programmers hard coding the
tab
> > stop
> > > in an untra grid.
> > > TIA for suggestions
> > > Patty Buechler
Currently when you launch the Issues List tab, it defaults to the
Assembly Seq.
We are attempting to change the Tab Stop of the default Ultra Grid.
We want to change it to default to the Issued Qty box and then hit
If I am trying to mass issue (quick issue materials), I want to enter
qty <enter>, enter qty <enter>, enter qty <enter> click OK to close the
I have opened a call with Epicor and their intial reponse was leaning
towards another example of their programmers hard coding the tab stop
in an untra grid.
TIA for suggestions
Patty Buechler
> Assembly Seq.
enter
the
leaning
stop
> in an untra grid.
> TIA for suggestions
> Patty Buechler
However, I have to tab six times just to get to the Issued Qty column.
Patty
> > Assembly Seq.
Grid.
hit
> enter
close
> the
> leaning
> stop
> > in an untra grid.
> > TIA for suggestions
> > Patty Buechler
The plot thickens.....
Maybe make all the fields except issued Qty read only (most likely by
code)
column.
> Patty
the
> > > Assembly Seq.
> Grid.
> hit
> > enter
> close
> > the
> > leaning
tab
> > stop
> > > in an untra grid.
> > > TIA for suggestions
> > > Patty Buechler
Patty,
Are you saying this ultragrid is different than (all) others I've ever seen (we don't use Mass issue so not familiar with it... Haven't looked at it since we were piloting) in that you can't set your column order to optimal order for your process & also set any extraneous potential entry fields to read only in the grid properties?
Rob
Patty
> > Assembly Seq.
Grid.
hit
> enter
close
> the
> leaning
> stop
> > in an untra grid.
> > TIA for suggestions
> > Patty Buechler
tab stop?
Patty Buechler
--- In vantage@yahoogroups.com, Robert Brown <robertb_versa@...>
wrote:
> Patty,
> Rob
> From: bpbuechler <pbuechler@...>
column.
> Patty
the
> > > Assembly Seq.
> Grid.
> hit
> > enter
> close
> > the
> > leaning
tab
> > stop
> > > in an untra grid.
> > > TIA for suggestions
> > > Patty Buechler
