Mass Issue to Mfg with Lot Numbers
Ok so I am polling the body of experts to see if there is a way to pull this off. Here are the tools I am familiar with: Predictive Search and BAQ Zone… plus a very small customization.
Issue. When mass issuing to a job with Lot Tracked parts, in order to load the lot number we must right click, open lot search, hit search select the appropriate lot number and click ok.
Desired solution. When I click in the LotNum section of Mass Issue List view a “Window” shows the available Lots for the part number of the selected row. “Window” can be a hover box, a customized section of the screen… anything. Next when I click the LotNum of choice it needs to populate the LotNum box in the issue list view.
So… any tips? other methods of achieving the solution that I need to educate myself on?
Thanks for the inputs. hopefully others might benefit from any solution we can come up with. we wil certainly update this post with the final outcome.
