Mass lock qty on Jobs
I might be able to help. In vantage 406 there a two fields pointing to the same thing. JobHead.LockedQty and JobHead.LockQty. Now, when I installed 409, JobHead.LockedQty has been removed and you are only left with JobHead.LockQty. I now have a working BPM that locks the qty of all new jobs.
--- In vantage@yahoogroups.com, "LakeIT" <inthespot1@...> wrote:
> We are currently experiencing a related issue. We would like to create a simple report to show what jobs have the Qty locked and what jobs do not. If we look in the customizaiton screen it shows the Qty Lock checkbox being saved in JobHead.LockedQty, but we cannot see that field in our JobHead Table.
> I have looked through the replies to your post and that ttJobHead is being referenced but I do not see that table in our DB.
> Our MRP is using the locked QTY field correctly, but we cannot seem to find it to report off of it.
> Any help would be appreciated.
Hello,
I need to mass lock the qty on all open jobs.
I created a BPM on the JobEntry\GetNewJobHead method.
On the condition (pre processing) I added:
the Jobhead.JobClosed field of all rows is equal to the FALSE value
Then on the Actions I created:
set the JobHead.LockedQty field of all rows to the TRUE value
I also put the above action in the post processing as well.
I went into job entry, created a test job and presto the Locked Qty is ticked, however, all the other jobs still have the locked qty unticked - how do I do this for all Jobs??
Thanks for any help
Michael Hutcheson
I created a preprocessing action on the Job Entry update.
action is to execute 4 gl code:
find first ttjobhead no-lock no-error.
if available ttjobhead.jobclosed = 'FALSE' then do:
ttjobhead.LockedQty = 'TRUE'
End
However, I keep receiving the following error:
Error Detail
Unknown database name ttjobhead. (855)
Unknown or ambiguous table jobclosed. (725)
** Could not understand line 23. (198)
Any ideas?
Michael.
--- In vantage@yahoogroups.com, "michael.hutcheson@..." <michael.hutcheson@...> wrote:
> Hello,
> Thanks for any help
> Michael Hutcheson
Try
if ttjobhead.JobClosed = 'FALSE' then do:
I think the AVAILABLE keyword is what is blowing it up
> End
> Error Detail
> Any ideas?
> Michael.
> --- In vantage@yahoogroups.com, "michael.hutcheson@" <michael.hutcheson@> wrote:
> > Hello,
> > Thanks for any help
> > Michael Hutcheson
Hello,
I tried:
find first ttjobhead where ttjobhead.rowmod = 'A' or ttjobhead.rowmod = 'U' no-error.
if ttjobhead.jobclosed = 'False' then do:
assign ttjobhead.lockedqty = 'TRUE'
End
But got:
Error Detail
** Incompatible data types in expression or assignment. (223)
** Could not understand line 22. (198)
Also tried:
find first ttjobhead where ttjobhead.rowmod = 'A' or ttjobhead.rowmod = 'U' and ttjobhead.jobclosed = 'FALSE' no-error.
if available ttjobhead then do:
End
But got:
Error Detail
** Could not understand line 21. (196)
Michael
--- In vantage@yahoogroups.com, "bw2868bond" <bwalker@...> wrote:
> Try
> > End
> > Error Detail
> > Any ideas?
> > Michael.
> > > Hello,
> > > Thanks for any help
> > > Michael Hutcheson
tried this:
find first job where ttjobhead.JobClosed = 'FALSE' no-lock no-error
if not available job then return
if available then do:
end
end
but got this:
The following application error was encountered:
** Line 24. Colon followed by white space terminates a statement. (199)
> Try
> > End
> > Error Detail
> > Any ideas?
> > Michael.
> > > Hello,
> > > Thanks for any help
> > > Michael Hutcheson
Hi,
Try removing the quotes around False and True.
Linda
Of michael.hutcheson@...
Sent: Thursday, November 26, 2009 8:17 AM
Subject: [Vantage] Re: Mass lock qty on Jobs
Hello,
I tried:
'U' no-error.
End
But got:
Error Detail
Also tried:
End
But got:
Error Detail
Michael
> Try
> > End
> > Error Detail
> > Any ideas?
> > Michael.
> > > Hello,
value
> > > Thanks for any help
> > > Michael Hutcheson
Hello,
Tried this:
For each ttjobhead where ttjobhead.RowMod = 'A' or ttjobhead.RowMod = 'U' and ttjobhead.LockedQty = 'False' no-lock:
If available ttJobhead then do:
Run lib\UpdateTableBuffer.p(input BUFFER ttJobHead:HANDLE,'LockedQty',True).
End.
But received:
Error Detail
Think its going to be a process of elimination!!
Michael
--- In vantage@yahoogroups.com, "Linda Lowney" <llowney@...> wrote:
> Hi,
> Linda
> Hello,
> I tried:
> 'U' no-error.
> End
> But got:
> Error Detail
> Also tried:
> End
> But got:
> Error Detail
> Michael
> "bw2868bond" <bwalker@> wrote:
> > Try
> > > End
> > > Error Detail
> > > Any ideas?
> > > Michael.
> > > > Hello,
> value
> > > > Thanks for any help
> > > > Michael Hutcheson
Sorry, should be:
For each ttjobhead where ttjobhead.RowMod = 'A' or ttjobhead.RowMod = 'U' and ttjobhead.JobClosed = 'False' no-lock:
End.
Still not working though
> Hello,
> Tried this:
> End.
> But received:
> Error Detail
> Michael
> --- In vantage@yahoogroups.com, "Linda Lowney" <llowney@> wrote:
> > Hi,
> > Linda
> > Hello,
> > I tried:
> > 'U' no-error.
> > End
> > But got:
> > Error Detail
> > Also tried:
> > End
> > But got:
> > Error Detail
> > Michael
> > > Try
> > > > End
> > > > Error Detail
> > > > Any ideas?
> > > > Michael.
> > > > > Hello,
> > value
> > > > > Thanks for any help
> > > > > Michael Hutcheson
Did you try removing the quotes around False ---- ttJobHead.JobClosed =
False no-lock:
Linda
Sent: Thursday, November 26, 2009 9:36 AM
Sorry, should be:
End.
> Hello,
> Tried this:
> End.
> But received:
> Error Detail
> Michael
> > Hi,
> > Linda
> > From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
Behalf
> > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > Hello,
> > I tried:
ttjobhead.rowmod =
> > 'U' no-error.
> > End
> > But got:
> > Error Detail
> > Also tried:
ttjobhead.rowmod =
> > End
> > But got:
> > Error Detail
> > Michael
> > > Try
> > > > End
> > > > Error Detail
> > > > Any ideas?
> > > > Michael.
<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ,
> > > > > Hello,
> > value
Locked
> > > > > Thanks for any help
> > > > > Michael Hutcheson
Yeah,
I tried this:
for each JobhHead where JobHead.JobClosed = FALSE no-lock:
if available JobHead then do:
Run lib\UpdateTableBuffer.p(input BUFFER JobHead:HANDLE, 'LockedQty',True).
End.
End
But receive this:
Error Detail
Unknown or ambiguous table JobhHead. (725)
Michael
> False no-lock:
> Linda
> Sorry, should be:
> End.
> > Hello,
> > Tried this:
> > End.
> > But received:
> > Error Detail
> > Michael
> > > Hi,
> > > Linda
> Behalf
> > > Hello,
> > > I tried:
> ttjobhead.rowmod =
> > > 'U' no-error.
> > > End
> > > But got:
> > > Error Detail
> > > Also tried:
> ttjobhead.rowmod =
> > > End
> > > But got:
> > > Error Detail
> > > Michael
> > > > Try
> > > > > End
> > > > > Error Detail
> > > > > Any ideas?
> > > > > Michael.
> > > > > > Hello,
> > > value
> Locked
> > > > > > Thanks for any help
> > > > > > Michael Hutcheson
Hi
Unknown or ambiguous table JobhHead. (725) - it looks like you have an
extra "h" in JobHead.
Linda
Sent: Thursday, November 26, 2009 9:57 AM
Yeah,
I tried this:
'LockedQty',True).
End.
End
But receive this:
Error Detail
Michael
> False no-lock:
> Linda
Behalf
> Sorry, should be:
> End.
> > Hello,
> > Tried this:
> > End.
> > But received:
> > Error Detail
> > Michael
> > > Hi,
> > > Linda
> Behalf
> > > Hello,
> > > I tried:
> ttjobhead.rowmod =
> > > 'U' no-error.
> > > End
> > > But got:
> > > Error Detail
> > > Also tried:
> ttjobhead.rowmod =
> > > End
> > > But got:
> > > Error Detail
> > > Michael
> > > > Try
> > > > > End
> > > > > Error Detail
> > > > > Any ideas?
> > > > > Michael.
> > > > > > Hello,
FALSE
> > > value
value
> Locked
qty
> > > > > > Thanks for any help
> > > > > > Michael Hutcheson
Yes so I do!!
Changed it to:
for each JobHead where JobHead.JobClosed = FALSE no-lock:
End.
End.
It now validates!!! Just tried to run it and vantage hangs, but it may be processing as I would imagine it will take some time to amend all open jobs...
Michael
> Hi
> Linda
> Yeah,
> I tried this:
> 'LockedQty',True).
> End.
> End
> But receive this:
> Error Detail
> Michael
> > False no-lock:
> > Linda
> Behalf
> > Sorry, should be:
> > End.
> > > Hello,
> > > Tried this:
> > > End.
> > > But received:
> > > Error Detail
> > > Michael
> > > > Hi,
> > > > Linda
> > Behalf
> > > > Hello,
> > > > I tried:
> > ttjobhead.rowmod =
> > > > 'U' no-error.
> > > > End
> > > > But got:
> > > > Error Detail
> > > > Also tried:
> > ttjobhead.rowmod =
> > > > End
> > > > But got:
> > > > Error Detail
> > > > Michael
> > > > > Try
> > > > > > End
> > > > > > Error Detail
> > > > > > Any ideas?
> > > > > > Michael.
> > > > > > > Hello,
> FALSE
> > > > value
> value
> > Locked
> qty
> > > > > > > Thanks for any help
> > > > > > > Michael Hutcheson
Although the below code is validated, it still does not lock the qty's of all open jobs. When you click save, ie. go through the job entry.update methods, its hangs for approx 4 mins, but then does not actually do any thing.
Any ideas?
Michael
> Yes so I do!!
> Changed it to:
> End.
> End.
> Michael
> > Hi
> > Linda
> > Yeah,
> > I tried this:
> > 'LockedQty',True).
> > End.
> > End
> > But receive this:
> > Error Detail
> > Michael
> > > False no-lock:
> > > Linda
> > Behalf
> > > Sorry, should be:
> > > End.
> > > > Hello,
> > > > Tried this:
> > > > End.
> > > > But received:
> > > > Error Detail
> > > > Michael
> > > > > Hi,
> > > > > Linda
> > > Behalf
> > > > > Hello,
> > > > > I tried:
> > > ttjobhead.rowmod =
> > > > > 'U' no-error.
> > > > > End
> > > > > But got:
> > > > > Error Detail
> > > > > Also tried:
> > > ttjobhead.rowmod =
> > > > > End
> > > > > But got:
> > > > > Error Detail
> > > > > Michael
> > > > > > Try
> > > > > > > End
> > > > > > > Error Detail
> > > > > > > Any ideas?
> > > > > > > Michael.
> > > > > > > > Hello,
> > FALSE
> > > > > value
> > value
> > > Locked
> > qty
> > > > > > > > Thanks for any help
> > > > > > > > Michael Hutcheson
Hi Michael,
I'm just learning BPMs and Progress too, but I did something similar for
memos. What is triggering your directive?
We use the ShortChar01 field in Memo entry to enter an initiator's name,
which was a free form field. I wanted them to pick someone from the
Person table so I wrote a BPM to change all the ShortChar01 fields to be
the person code, and since I'm never an initiator on memos I decided to
use my person code as a trigger.
My preprocessing condition was the ttMemo.shortChar01 field has been
changed from any to 'llowney'
My preprocessing action was enable dependent post process directives
My postprocessing condition was this directive has been enabled from the
ck for change in shortchar02 directive
My postprocessing action was similar to yours except I did not have the
no-lock at the end of the for each statement.
for each Memo where Memo.Company = "PS01" and Memo.ShortChar01 = "Barb
Kirkey".
Run lib\UpdateTableBuffer.p(input BUFFER Memo:HANDLE,'ShortChar01',
"BKirkey").
end.
Regards,
Linda
Sent: Thursday, November 26, 2009 10:41 AM
Any ideas?
Michael
> Yes so I do!!
> Changed it to:
'LockedQty',True).
> End.
> End.
open jobs...
> Michael
> > Hi
an
> > Linda
Behalf
> > Yeah,
> > I tried this:
> > 'LockedQty',True).
> > End.
> > End
> > But receive this:
> > Error Detail
> > Michael
ttJobHead.JobClosed
> > > False no-lock:
> > > Linda
> > Behalf
> > > Sorry, should be:
ttjobhead.RowMod =
> > > End.
> > > > Hello,
> > > > Tried this:
ttjobhead.RowMod
> > > > End.
> > > > But received:
> > > > Error Detail
> > > > Michael
> > > > > Hi,
> > > > > Linda
> > > Behalf
> > > > > Hello,
> > > > > I tried:
> > > ttjobhead.rowmod =
> > > > > 'U' no-error.
> > > > > End
> > > > > But got:
> > > > > Error Detail
> > > > > Also tried:
> > > ttjobhead.rowmod =
> > > > > End
> > > > > But got:
> > > > > Error Detail
> > > > > Michael
> > > > > > Try
> > > > > > > End
> > > > > > > Error Detail
> > > > > > > Any ideas?
> > > > > > > Michael.
> > > > > > > > Hello,
> > FALSE
> > > > > value
> > value
well.
> > > Locked
locked
> > qty
> > > > > > > > Thanks for any help
> > > > > > > > Michael Hutcheson
Hello Linda,
The directive is triggered by the job entry.update - so I was just making one change then clicking save to trigger the action.
So did you get it to update all memo\shortchar01 to "BKirkey" across the whole database? The only thing missing from mine now would seem the company. I had no conditions, only actions. I've tried it on pre\processing as well.
PS. I'm in the UK so will be going home in about 20 mins.
Michael
> Hi Michael,
> Kirkey".
> "BKirkey").
> end.
> Regards,
> Linda
> Any ideas?
> Michael
> > Yes so I do!!
> > Changed it to:
> 'LockedQty',True).
> > End.
> > End.
> open jobs...
> > Michael
> > > Hi
> an
> > > Linda
> Behalf
> > > Yeah,
> > > I tried this:
> > > 'LockedQty',True).
> > > End.
> > > End
> > > But receive this:
> > > Error Detail
> > > Michael
> ttJobHead.JobClosed
> > > > False no-lock:
> > > > Linda
> > > Behalf
> > > > Sorry, should be:
> ttjobhead.RowMod =
> > > > End.
> > > > > Hello,
> > > > > Tried this:
> ttjobhead.RowMod
> > > > > End.
> > > > > But received:
> > > > > Error Detail
> > > > > Michael
> > > > > > Hi,
> > > > > > Linda
> > > > Behalf
> > > > > > Hello,
> > > > > > I tried:
> > > > ttjobhead.rowmod =
> > > > > > 'U' no-error.
> > > > > > End
> > > > > > But got:
> > > > > > Error Detail
> > > > > > Also tried:
> > > > ttjobhead.rowmod =
> > > > > > End
> > > > > > But got:
> > > > > > Error Detail
> > > > > > Michael
> > > > > > > Try
> > > > > > > > End
> > > > > > > > Error Detail
> > > > > > > > Any ideas?
> > > > > > > > Michael.
> > > > > > > > > Hello,
> > > FALSE
> > > > > > value
> > > value
> well.
> > > > Locked
> locked
> > > qty
> > > > > > > > > Thanks for any help
> > > > > > > > > Michael Hutcheson
Hi Michael,
I actually had a lot of different names, initials etc to change so the
program was very long and yes it worked ok for me.
Regards,
Linda
Sent: Thursday, November 26, 2009 11:14 AM
Hello Linda,
Michael
> Hi Michael,
for
name,
be
to
the
the
> Kirkey".
> "BKirkey").
> end.
> Regards,
> Linda
Behalf
> Any ideas?
> Michael
> > Yes so I do!!
> > Changed it to:
> 'LockedQty',True).
> > End.
> > End.
may
> open jobs...
> > Michael
> > > Hi
have
> an
> > > Linda
> Behalf
> > > Yeah,
> > > I tried this:
> > > 'LockedQty',True).
> > > End.
> > > End
> > > But receive this:
> > > Error Detail
> > > Michael
> ttJobHead.JobClosed
> > > > False no-lock:
> > > > Linda
> > > Behalf
> > > > Sorry, should be:
> ttjobhead.RowMod =
> > > > End.
> > > > > Hello,
> > > > > Tried this:
> ttjobhead.RowMod
> > > > > End.
> > > > > But received:
> > > > > Error Detail
> > > > > Michael
> > > > > > Hi,
> > > > > > Linda
> > > > Behalf
> > > > > > Hello,
> > > > > > I tried:
> > > > ttjobhead.rowmod =
> > > > > > 'U' no-error.
> > > > > > End
> > > > > > But got:
> > > > > > Error Detail
(223)
> > > > > > Also tried:
> > > > ttjobhead.rowmod =
> > > > > > End
> > > > > > But got:
> > > > > > Error Detail
(223)
> > > > > > Michael
> > > > > > > Try
update.
> > > > > > > > End
> > > > > > > > Error Detail
> > > > > > > > Any ideas?
> > > > > > > > Michael.
> > > > > > > > > Hello,
the
> > > FALSE
> > > > > > value
TRUE
> > > value
> well.
the
> > > > Locked
> locked
> > > qty
> > > > > > > > > Thanks for any help
> > > > > > > > > Michael Hutcheson
You don't need the "If AVAILABLE" condition with the "For Each" loop.
Try:
End.
Dele Oyebande
> Any ideas?
> Michael
> > Yes so I do!!
> > Changed it to:
> > End.
> > End.
> > Michael
> > > Hi
> > > Linda
> > > Yeah,
> > > I tried this:
> > > 'LockedQty',True).
> > > End.
> > > End
> > > But receive this:
> > > Error Detail
> > > Michael
> > > > False no-lock:
> > > > Linda
> > > Behalf
> > > > Sorry, should be:
> > > > End.
> > > > > Hello,
> > > > > Tried this:
> > > > > End.
> > > > > But received:
> > > > > Error Detail
> > > > > Michael
> > > > > > Hi,
> > > > > > Linda
> > > > Behalf
> > > > > > Hello,
> > > > > > I tried:
> > > > ttjobhead.rowmod =
> > > > > > 'U' no-error.
> > > > > > End
> > > > > > But got:
> > > > > > Error Detail
> > > > > > Also tried:
> > > > ttjobhead.rowmod =
> > > > > > End
> > > > > > But got:
> > > > > > Error Detail
> > > > > > Michael
> > > > > > > Try
> > > > > > > > End
> > > > > > > > Error Detail
> > > > > > > > Any ideas?
> > > > > > > > Michael.
> > > > > > > > > Hello,
> > > FALSE
> > > > > > value
> > > value
> > > > Locked
> > > qty
> > > > > > > > > Thanks for any help
> > > > > > > > > Michael Hutcheson
Hello,
Thanks for this.
Tried the code but received the following when validating:
** Unknown table name er. (200)
** Could not understand line 22. (196)
Michael
> Try:
> End.
> Dele Oyebande
> > Any ideas?
> > Michael
> > > Yes so I do!!
> > > Changed it to:
> > > End.
> > > End.
> > > Michael
> > > > Hi
> > > > Linda
> > > > Yeah,
> > > > I tried this:
> > > > 'LockedQty',True).
> > > > End.
> > > > End
> > > > But receive this:
> > > > Error Detail
> > > > Michael
> > > > > False no-lock:
> > > > > Linda
> > > > Behalf
> > > > > Sorry, should be:
> > > > > End.
> > > > > > Hello,
> > > > > > Tried this:
> > > > > > End.
> > > > > > But received:
> > > > > > Error Detail
> > > > > > Michael
> > > > > > > Hi,
> > > > > > > Linda
> > > > > Behalf
> > > > > > > Hello,
> > > > > > > I tried:
> > > > > ttjobhead.rowmod =
> > > > > > > 'U' no-error.
> > > > > > > End
> > > > > > > But got:
> > > > > > > Error Detail
> > > > > > > Also tried:
> > > > > ttjobhead.rowmod =
> > > > > > > End
> > > > > > > But got:
> > > > > > > Error Detail
> > > > > > > Michael
> > > > > > > > Try
> > > > > > > > > End
> > > > > > > > > Error Detail
> > > > > > > > > Any ideas?
> > > > > > > > > Michael.
> > > > > > > > > > Hello,
> > > > FALSE
> > > > > > > value
> > > > value
> > > > > Locked
> > > > qty
> > > > > > > > > > Thanks for any help
> > > > > > > > > > Michael Hutcheson
Ok, I've got it to validate. When I run it, Vantage hangs for about 5 mins, comes back to life but all of the jobs don't have a locked qty.....
Michael
> Hello,
> Thanks for this.
> Michael
> > Try:
> > End.
> > Dele Oyebande
> > > Any ideas?
> > > Michael
> > > > Yes so I do!!
> > > > Changed it to:
> > > > End.
> > > > End.
> > > > Michael
> > > > > Hi
> > > > > Linda
> > > > > Yeah,
> > > > > I tried this:
> > > > > 'LockedQty',True).
> > > > > End.
> > > > > End
> > > > > But receive this:
> > > > > Error Detail
> > > > > Michael
> > > > > > False no-lock:
> > > > > > Linda
> > > > > Behalf
> > > > > > Sorry, should be:
> > > > > > End.
> > > > > > > Hello,
> > > > > > > Tried this:
> > > > > > > End.
> > > > > > > But received:
> > > > > > > Error Detail
> > > > > > > Michael
> > > > > > > > Hi,
> > > > > > > > Linda
> > > > > > Behalf
> > > > > > > > Hello,
> > > > > > > > I tried:
> > > > > > ttjobhead.rowmod =
> > > > > > > > 'U' no-error.
> > > > > > > > End
> > > > > > > > But got:
> > > > > > > > Error Detail
> > > > > > > > Also tried:
> > > > > > ttjobhead.rowmod =
> > > > > > > > End
> > > > > > > > But got:
> > > > > > > > Error Detail
> > > > > > > > Michael
> > > > > > > > > Try
> > > > > > > > > > End
> > > > > > > > > > Error Detail
> > > > > > > > > > Any ideas?
> > > > > > > > > > Michael.
> > > > > > > > > > > Hello,
> > > > > FALSE
> > > > > > > > value
> > > > > value
> > > > > > Locked
> > > > > qty
> > > > > > > > > > > Thanks for any help
> > > > > > > > > > > Michael Hutcheson
