Mass Parts movement Whse/Bin to Whse/Bin in 9.05.605B
All cycle counts were closed before we started and no new ones were created until we were done and Finance was happy. We actually used the opportunity to do a physical on those two warehouses while we were at it so the reset to the count date was ok for us.
--- In vantage@yahoogroups.com, "erp07052" <erp07052@...> wrote:
> Good morning.
> What affect did this have on any of your already scheduled cycles?
> Or did you NOT have any cycle counts already scheduled and selected?
> thanks
> --- In vantage@yahoogroups.com, "amvarghai" <amin@> wrote:
> > Thanks for suggestion. I will try this for sure.
> > --- In vantage@yahoogroups.com, "Kirstin Brandt" <kirstin.brandt@> wrote:
> > > We did this by doing a physical inventory for both warehouses, copying the resulting cycle count data to Excel, adding or appending the counts from WH B into WH A, changing the counts in WH A to zero, then carefully paste-updating the results back into cycle counting. Requires someone decent at Excel and very careful with data, but completely free and not bypassing Epicor's logic.
> > > > Hi,
> > > > I apologize if this question has been asked and answered before. In that case please point me to the right thread.
> > > > we had two warehouse (A & B). We have consolidated and got rid of warehouse B. We are trying to reassign about 20K different parts that were in WH B into WH A. It is pretty time consuming to do them one by one. Epicor does not a have batch method for this at the moment. They told to look into DMT or create a updatable BAQ with BPM. They don't have a document for it. It was just a guidance.
> > > > We also asked our consultants for a solution and it seems the cost is $5,000+. That seems a bit excessive for a tool we would use just once.
> > > > I am wondering if anyone has come across this problem before and what method you used to solve the problem?
> > > > thanks,
> > > > Amin
Hi,
thanks,
Amin
Use DMT. Don't remember the exact cost off-hand, but less than that
$5,000+.
We're starting the move of a plant & some outlying warehouses into one
larger building, with physical moves staggered over the next couple of
months. DMT is great for this: write a query to pull all the on-hand
qty for a warehouse/bin, export in the CSV format required by DMT (with
hardcoded destination whse/bin), and process it all automatically as an
inventory transfer. Poof!
Brian.
Of amvarghai
Sent: Tuesday, October 16, 2012 12:30 PM
Subject: [Vantage] Mass Parts movement Whse/Bin to Whse/Bin in 9.05.605B
Hi,
thanks,
Amin
If you're SQL, you're set -- Carefully do an update. Otherwise, updatable
BAQs are easy. DMT is ridiculously expensive.
amvarghai
Hi,
thanks,
Amin
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2012.0.2221 / Virus Database: 2441/5334 - Release Date: 10/15/12
Your consultant should be able to write a simple BPM to do this its not too
bad.
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
<http://www.usdoingstuff.com>
On Tue, Oct 16, 2012 at 2:35 PM, Vic Drecchio
> Of
> amvarghai
> Hi,
> method
> thanks,
> Amin
--- In vantage@yahoogroups.com, "amvarghai" <amin@...> wrote:
> Hi,
> thanks,
> Amin
> > Hi,
> > thanks,
> > Amin
I thought it would be a simple BPM as well, but apparently I have to learn BPMs or switch consultants.
thanks for the suggestion.
> bad.
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > Of
> > amvarghai
> > Hi,
> > method
> > thanks,
> > Amin
Good morning.
thanks
> > > Hi,
> > > thanks,
> > > Amin
