Mass Printing on PO's
Is there a way to disable epicor from changing PO’s to change orders after I print a PO? I took out the big “CHANGE ORDER” at the top of all the PO forms because I never liked that and I want the ready for mass print box to always be checked but it unchecks when epicor makes PO’s into change orders. I’m sure I can write a BPM to stop that but can I just disable that instead?
That functionality to disable mass printing after printing, is so that you can use the Mass Printing without worrying about re-printing previously printed PO’s.
And marking them as “change order” after printing, ensures that any future reprints are identified as changed (even if they are not). That ensures the receiver of the PO knows that they have to look it over, and not just assume they already got this one.
Would you manually uncheck mass print after printing then? If not, you would end up printing every PO ever created, every time you mass print.
It always unchecks when you print, whether that be manually or via mass print @zwilli526 .
