Mass Resource Group Reassign
We have a need to move all operations from one resource group to another on an existing job. I have tried along with Epicor consultants to do this with method directives on JobEntry and data directives on JobHead.
The code gets called so often it is a drag on the system.
I think a standalone menu choice something like Mass Resource Group replace, but on a job would work, but it is beyond my Epicor knowledge to pull it off.
Has anyone else had this situation and how was it approached?
Thanks for any suggestions.
Greg Payne
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at (727) 578-6258 and immediately delete the communication.
