I found this message doing a search for mass replace and didn't see
if you ever got a response. Here's an idea though...you could change
the description of the old resource group and the costs to what you
are setting the new one to. Then do your replace, then go back and
change the descriptions/cost back to the original. I would think
that little bit of work would still be better than having to manually
change all of the individual MOM's.
--- In vantage@yahoogroups.com, tblakely@... wrote:
> Has anyone used the Mass Resource Group Replace? It will change the
> resource group on all the routings and make a nice little note in
the audit
> log describing the change. What it doesn't do is change the
Resource Group
> description or the values. I called this in and Epicor says that
is what
> it's suppose to do. If I were to replace an older piece of
equipment with
> a new one, why would you ever want to retain the description or
value of
> the older equipment?
