Service connect can talk to the UD tables.
~Charlie
_____
kenjirak
Sent: Wednesday, July 22, 2009 7:49 AM
Subject: [Vantage] Re: Mass update user defined fields?
Wow,
Sounds like it is a little more than I am capable of at this point.
Thank you for the reply!
Ken
--- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com, Steven
Gotschall <sgotschall@...> wrote:
through ODBC, but as long as you are confidant that the only thing you are
touching are UD fields, then there shouldn't be a problem.
using a updatetablebuffer call.
be beneficial if we could mass update these fields using an Excell
spreadsheet (similar to the "Customer/Contact Import" process). If there is
a way to do this I would like to build it into the customization prior to
deploying.
~Charlie
_____
kenjirak
Wow,
Ken
>ways.
> Its possible, but not straight forward. I've done this two different
>Generally speaking you should not update or change anything in Vantage
> One way is to use ODBC (or JDBC if you use something like Squirrel SQL.
>run the code and then have it loop through your table updating the records
> Another way is through 4GL code. You would have to create a "trigger" to
>fields?
> From: kenjirak <kenjirak@...>
> To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
> Sent: Tuesday, July 21, 2009 4:50:11 PM
> Subject: [Vantage] Mass update user defined fields?
> Does anyone know if it is possible to do a mass update of user defined
> We are looking to create some customizations in customer Maint and Ship toscreens that will hold some special customer ranking information. It would
deploying.
>[Non-text portions of this message have been removed]
> We are running V8.03.406A
> Thank you,
> Ken
