Material Options on Part Master
I was wondering if there is some obvious solution I am missing.
We have a part that we make that is normally made of a specific material. In
the legacy ERP system production control is able to select from a list of
approved alternative materials to use.
For Example:
We are making Widget A. In the current system it will tell you that widget A
can be made of Material A, B, or C.
I think Vantage's part substitute feature will let you substitute Material A
for B or C or D or E but it does not reference Widget A to see whats allowed.
Although Material B can be substituted for Material A in Widget A, that may
not be the case for Widget B.
I hope I made sense.
Thanks for the help,
Jeremy
