Material Overhead Field in 9.05.607B
We are currently on Epicor Version 9.05.607B.
We are investigating using the material overhead field in Epicor and would appreciate your input/advice:
· Has anyone come up with a way to do a mass update in Epicor to automatically put in the material overhead cost based on a fixed % of the material cost (i.e. 5% of the material cost)?
· For the users that are using the material overhead field how does it work for the overhead applied? Is it based on the material dollars received times the material overhead factor?
· Any other input/suggestions will be greatly appreciated.
Thank-you in advance for your help/suggestions.
