Material Qeueu Filter
Created a filter for the material queue for our handlers. It hides all the backflush/automove operations, that have no value in the “Requested By” column, and only shows requests made by the work crew. You’ll have to create a checkbox on the queue screen. I named mine cbhide but you can use whatever works best for you.
Anyway, thought I would share:
// Custom code for MaterialQueueEntryForm
// Created: 3/5/2019 2:14:20 PM
using System;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using Erp.Adapters;
using Erp.UI;
using Ice.Lib;
using Ice.Adapters;
using Ice.Lib.Customization;
using Ice.Lib.ExtendedProps;
using Ice.Lib.Framework;
using Ice.Lib.Searches;
using Ice.UI.FormFunctions;
using Infragistics.Win;
using Infragistics.Win.UltraWinGrid;
using Infragistics.Shared;
public class Script
EpiUltraGrid gridmtl;
gridmtl = (Ice.Lib.Framework.EpiUltraGrid)csm.GetNativeControlReference("09bbac04-0c14-449b-9f99-b66bbf58dd6e");
	gridmtl.DisplayLayout.Override.AllowRowFiltering = DefaultableBoolean.True;
		this.cbhide.CheckedChanged += new System.EventHandler(this.cbhide_CheckedChanged);
		this.cbhide.CheckedChanged -= new System.EventHandler(this.cbhide_CheckedChanged);
		// Begin Custom Code Disposal
		// End Custom Code Disposal
	private void cbhide_CheckedChanged(object sender, System.EventArgs args)
		if (cbhide.Checked == true)  //filter if checked
		        gridmtl.DisplayLayout.Bands[0].ColumnFilters["RequestedByEmpID"].FilterConditions.Add  (FilterComparisionOperator.NotEquals, "");
		if (cbhide.Checked == false)
			gridmtl.DisplayLayout.Bands[0].ColumnFilters["RequestedByEmpID"].FilterConditions.Clear();
Hopefully someone will find this useful. I know it helped our material handlers out.
