This is probably obvious to SQL people, but can I do math on columns in a union?
I have two subqueries - one is a summary of UD08 (production goals) and the other is a summary of Project (actual production). One is the top level and the other is a union.
How well we are doing is the math between them. So in this example (from a pic from last week), we are -14 for “Offline to date” - that’s 77-63.
Can a BAQ do this math itself, to subtract the union from the top level?
I can think of two ways to do this off the top of my head - and depending on how you use this table, it might make more sense to go one path vs. the other.
Make a new top level subquery and pick the first subquery in the union… which you would change to a CTE subquery.
Running total:
To do a “running total” you can do a sum over partition by type calculated field. Effectively, you’d partition by Range here and Order by Type. I can send an example of something I’ve done like this or you can google that.
Subquery with Calculated Field:
Group By Range and create 6 calculated fields (Goals and Actuals for each column). Then for each of the calc fields, do a case statement to sum the column only if the type = goals or actuals. Then you can do a calculated field for each of the columns to get the difference… something like (Gold To Date Actuals) - (Gold To Date Goals)
So, the running total - I think this is an additional field in the same dataset? So I’d still have 2 rows but additional columns? Not a third row, right?
Then the subquery - I think results in 1 row with lots of fields? (3 per old numerical column)
Edit: I see that I didn’t explain what I wanted in a good way. You certainly did answer the question. But I was thinking of having the math in a new, third row. Like you might do in Excel.
FYI, I’d like this to work in Epicor, but ultimately the goal is to email the report daily, so I think at that point I can live with it as is and manipulate the format as needed. I think.
But if this can be done all at once, all the better.
If you’re trying to email the report, and you’re creating a report for this… let the report do the work.
You can put in a calculated field in your report as a new row under the data table you are putting in there. That’s yet another option. Might be the easiest option, honestly.
