I'm getting this message on the client side as well as the Epicor Admin Console. I have re-booted the server and it didn't go away. Any Ideals on how to clean this up?
We went live this morning on 6.1 (from 4.00.904). We are getting a message
for maximum number of users being exceeded when we should have some
available. How do I view the users on the system? Has promon disappeared?
Is this a max users message or the one that says to increase the -n parameter? 6.1 installs with some default settings for the database that restricts the number of users to 10. You can run the database optimization routine or call support for advice on the settings for your number of users (via Progress Explorer). It will require a reboot of the server to take effect. Promon is still around you just have to manually create a shortcut to it.
-Todd C.
Sent: Wednesday, February 02, 2005 7:53 AM
To: Vantage (E-mail)
Subject: [Vantage] Maximum number of users exceeded
_____
Yahoo! Groups Links
vantage-unsubscribe@yahoogroups.com <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
-Todd C.
_____
Yahoo! Groups Links
You can look at your logged in sessions to vantage through system Management
-> Utilities -> "connected users". This will show you all the current
database connections. If you view this from the server, you can also
disconnect users directly from this window. (I am on 5.2 - I assume this is
the same in 6.1)
_____
Yahoo! Groups Links
Yahoo! Groups Links
the same in 6.1)
_____
Yahoo! Groups Links
Yahoo! Groups Links
Is there any way of knowing how many times a day my users get the" Maximum number of users exceeded" message when logging in to Vantage. I'm trying to justify more licenses to our owner.
Rich Wagner
[cid:image003.jpg@01CB6C50.71766880]
2148 Century Drive
Jefferson Hills, PA 15025
Phone: (412) 384-3100 x159
Fax: (412) 384-2033
www.bawplastics.com<http://www.bawplastics.com/>
Rich Wagner
2148 Century Drive
Fax: (412) 384-2033
I would imagine there is something written in a log file somewhere. I
don't know where though.
Blake Clemens
IT Systems Engineer
Delmarva Millwork Corporation
(800) 360-2364 x132
Of RICH WAGNER
Sent: Friday, October 15, 2010 10:05 AM
Rich Wagner
<mailto:image003.jpg%4001CB6C50.71766880> ]
2148 Century Drive
Fax: (412) 384-2033
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Of RICH WAGNER
Rich Wagner
2148 Century Drive
Fax: (412) 384-2033
Turn on verbose logging and it will appear in the app server logs.
> Thanks,
> Blake Clemens
> IT Systems Engineer
> (800) 360-2364 x132
> From: vantage@yahoogroups.com <vantage%40yahoogroups.com> [mailto:
> vantage@yahoogroups.com <vantage%40yahoogroups.com>] On Behalf
> Of RICH WAGNER
> To: vantage@yahoogroups.com <vantage%40yahoogroups.com>
> Thanks,
> Rich Wagner
> [cid:image003.jpg@01CB6C50.71766880 <image003.jpg%4001CB6C50.71766880>
> <mailto:image003.jpg%4001CB6C50.71766880<image003.jpg%254001CB6C50.71766880>>
> 2148 Century Drive
> Fax: (412) 384-2033
Log into epicor admin console, (you might have to have uses log out to get a session to log in)
All pgms/epicor software/epicor admin tools/epicor administration console.
Under server management connect to your server and then epicor904
Click on sessions.
Under license filter usage (on right of screen click select all )
You can cancel the greyed out ones to get more sessions.
However, we've run into this and even when it only appears you are using half of your licenses – something still makes it think they are all in use. Per epicor – at that point you need to restart the database.
Click on sessions.
> Thanks,
> Blake Clemens
> IT Systems Engineer
> (800) 360-2364 x132
> Of RICH WAGNER
> Thanks,
> Rich Wagner
> [cid:image003.jpg@...
> 2148 Century Drive
> Fax: (412) 384-2033
