What I've done to combat this error is to make departmental .prls. Then
copied the appropriate departmental reports to the prl. I then deleted the
extra reports in the offending prl. The custom reports list doesnt care
which prl it pulls from. You will have to go back into the custom reports
menu to REPOINT to the appropriate prl.
Shirley Graver
(End User)
Sys Admin
Rubber associates Inc.
Cleveland/Akron
paul.siebers@...]
Sent: Wednesday, June 27, 2001 2:23 PM
To: '
vantage@yahoogroups.com'
Subject: RE: [Vantage] Maximum # of reports in .prl file?
Tried that, however when selecting the .prl menu I get an error message (
Entry 181 is out of the range of list...followed by a large list of report
names). When I click OK I am presented with a much smaller version of
what
should be in the .prl menu. I created a new .prl menu and plugged the
report into it, then I was able to pull it up without any problems. I
guess
there is a limit to the number of reports a .prl menu can contain.
egiallombardo@...]
Sent: Wednesday, June 27, 2001 12:55
To: '
Subject: RE: [Vantage] Re: Reports
You have to link reports to Vantage by clicking Edit-Add in the custom
report link browser and then you can select the report library and custom
report from the pull-down menus.
paul.siebers@...]
Sent: Wednesday, June 27, 2001 10:35 AM
To: '
Adding to the question; How come some of my reports in my .prl menu are
not
showing up in the Custom Report Link Maintenance browser?
TIA,
Paul
egiallombardo@...]
Sent: Wednesday, June 27, 2001 10:55
To: '
Two Levels down in almost every folder there is a folder called Master
File
Maintainance, in that is the Custom Report Link that links to the PRL file
and Report.
sbeals@... [mailto:
sbeals@...]
Sent: Wednesday, June 27, 2001 8:00 AM
To:
Subject: [Vantage] Re: Reports
Thanks, but one last question since I am new to version 4....where do
I find Master File Maintainance....
--- In vantage@y..., "Tim Care" <ecfmis@e...> wrote:
> If you are trying to run them from a Vantage menu,
> then you need to change the definition of the
> Custom Report in the menu structure. Under Master File
> Maintenance, there is a Custom Report Link that tells what
> PRL file to use, and what Report to use out of that PRL.
> Hope this helps.
> Tim Care
> Electro Chemical Finishing
> 3 Days to Version 5!!!
> From: <sbeals@b...>
> To: <vantage@y...>
> Sent: Wednesday, June 27, 2001 8:16 AM
> Subject: [Vantage] Reports
> > after a backup restore of version 3, we converted to version 4.
Now
> > whenever we try to run a custom report, we are getting an error
that
> > says the menu.prl cannot be found in the directory...which is not
the
> > correct directory of where our libraries our. I opened the report
in
> > report builder and saved it with the new parameters and services
and
> > am still getting this error. Is there anywhere else in the system
I
> > need to look at to change the path of the reports?
> > Thanks
> > To access the Files Section of our Yahoo!Group for Report Builder
and
> Crystal Reports and other 'goodies', please go to:
< http://groups.yahoo.com/group/vantage/files/.
<http://groups.yahoo.com/group/vantage/files/.> >
<http://groups.yahoo.com/group/vantage/files/.> > >
<http://groups.yahoo.com/group/vantage/files/.> > > > Note: You must
have
already
> linked your email address to a yahoo id to enable access.
> > Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> <
http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> > <
http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> > >
Yahoo! Groups Sponsor
http://rd.yahoo.com/M=180183.1330095.2920385.1269402/D=egroupmail/S=1700007
<http://rd.yahoo.com/M=180183.1330095.2920385.1269402/D=egroupmail/S=1700007
183:N/A=596658/?
<http://rd.yahoo.com/M=180183.1330095.2920385.1269402/D=egrou>
< http://rd.yahoo.com/M=180183.1330095.2920385.1269402/D=egrou
<http://rd.yahoo.com/M=180183.1330095.2920385.1269402/D=egrou> >
<http://rd.yahoo.com/M=180183.1330095.2920385.1269402/D=egrou> > >
pmail/S=1700007183:N/A=596658/R=0/* http://store.yahoo.com
<http://store.yahoo.com>
< http://store.yahoo.com <http://store.yahoo.com> >
< http://store.yahoo.com <http://store.yahoo.com> <
<http://store.yahoo.com> > > > Click Here!
http://us.adserver.yahoo.com/l?M=180183.1330095.2920385.1269402/D=egroupmai
<http://us.adserver.yahoo.com/l?M=180183.1330095.2920385.1269402/D=egroupmai
l/S=1700007183:N/A=596658/rand=739355727>
To access the Files Section of our Yahoo!Group for Report Builder and
have
already linked your email address to a yahoo id to enable access.
Your use of Yahoo! Groups is subject to the Yahoo! Terms of
< http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> <
Service.
183:N/A=596659/?
pmail/S=1700007183:N/A=596659/R=0/* http://store.yahoo.com
< http://store.yahoo.com <http://store.yahoo.com> > > Click Here!
l/S=1700007183:N/A=596659/rand=754471485>
<http://groups.yahoo.com/group/vantage/files/.> > > Note: You must have
Service.
http://rd.yahoo.com/M=202225.1433492.3029752.1269402/D=egroupmail/S=1700007
<http://rd.yahoo.com/M=202225.1433492.3029752.1269402/D=egroupmail/S=1700007
183:N/A=675622/*
http://altfarm.mediaplex.com/ad/ck/1177-3936-1039-2?mpt=9936
<http://altfarm.mediaplex.com/ad/ck/1177-3936-1039-2?mpt=9936>
56827> []
http://us.adserver.yahoo.com/l?M=202225.1433492.3029752.1269402/D=egroupmai
<http://us.adserver.yahoo.com/l?M=202225.1433492.3029752.1269402/D=egroupmai
l/S=1700007183:N/A=675622/rand=566884995>
<http://groups.yahoo.com/group/vantage/files/.> > Note: You must have
< http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> >
Service.
183:N/A=675622/*http://altfarm.mediaplex.com/ad/ck/1177-3936-1039-2?mpt=9936
60985> []
l/S=1700007183:N/A=675622/rand=418813599>
<http://groups.yahoo.com/group/vantage/files/.> Note: You must have
<http://docs.yahoo.com/info/terms/> Service.
http://groups.yahoo.com/group/vantage/files/. Note: You must have already
