Memory leak
You may be confusing Virtual Memory with - Memory. The following is from
W2K help.
It sounds like you need to increase the size of your virtual memory file.
See if this helps.
Nancy Dunn
Winco Ind.
To change the size of the virtual memory paging file
Open Computer Management (Local).
In the console tree, right-click Computer Management (Local), and then
select Properties.
On the Advanced tab, click Performance Options, and under Virtual memory,
click Change.
In the Drive list, click the drive that contains the paging file you want to
change.
Under Paging file size for selected drive, type a new paging file size in
megabytes in the Initial Size (MB) or Maximum Size (MB) box, and then click
Set.
If you decrease the size of either the minimum or maximum page file
settings, you must restart your computer to see the effects of those
changes. Increases generally do not require a restart.
Notes
You must be recognized as an administrator or a member of the Administrators
group on your computer and on the computer you are managing in order to
perform this task.
To open Computer Management, click Start, point to Settings, and then click
Control Panel. Double-click Administrative Tools, and then double-click
Computer Management.
You can view or change system properties on a remote computer or a local
computer. To access a remote computer, right-click Computer Management
(Local), click Connect to another computer, and then select the computer you
want to connect to in the list.
For best performance, set the initial size to not less than the recommended
size under Total paging file size for all drives. The recommended size is
equivalent to 1.5 times the amount of RAM on your system.
Usually, you should leave the paging file at its recommended size, although
you might increase its size if you routinely use programs that require a lot
of memory.
To delete a paging file, set both initial size and maximum size to zero.
Related Topics
Sent: Wednesday, December 26, 2001 1:57 PM
Subject: [Vantage] memory leak
Is there any issue with W2k server and vantage and memory leaking? I
continually have errors about virtual memory being too low. Rebooted
server on Xmas eve. Today it is very slow and required to be
rebooted because people couldn't get in and if they could they could
not open reports.
not open reports.
