Menu Call - is a BO fired?
Hi,
I am in the process of upgrading to 10.2.4 and using the opportunity to clear down dashboards, baq and customisations that are no longer used.
I have written method directives to capture dashboard and baq usage, however, I cannot find a BO to write the method directive for logging menu calls.
I know their is an extension that does this, but I just wondered whether there was a simpler and cheaper option.
Andrew.
Server logging may be a better option as it tracks everything for you. The Performance Diagnostic Tool can help you read it.
Thanks for the pointer
In the end I got the client to purchase the menu usage tracker.
It’s not too expensive and works as required.
