Yes, I have been setting up report styles, and they work well in most
situations. The problem I have, is that I have one group of people
who will run this report several times a day using one style, and
another group of people who will run it several times a day using
another style. I was just hoping for a way to create an icon for each
group that defaulted to the required style to avoid confusion.
Granted it is one simple step, but if it could be removed it would be
of benefit.
Thank you,
Craig
--- In vantage@yahoogroups.com, "laidig.systems" <laidig.systems@...>
of benefit.
Thank you,
Craig
wrote:
>You
> If all you did was create a new style for the production detail
> report, you don't have to mess with adding anything to the menu.
> can just run the normal production detail report. on the optionsform
> for the report, there is a dropdown labeled "report style". selectthe
> your newly created report style from this list.
> --- In vantage@yahoogroups.com, "Craig Weiss" <cweiss@> wrote:
> > I understand how to make it a new report, but how can you call
> > report from the menu. None of the program types allow me toselect
> > the report I created. The production detail's type is menu item,but
> > this only allows the selection of a program. Any guidance wouldbe
> > greatly appreciated.no
> > Thanks,
> > Craig
> > --- In vantage@yahoogroups.com, "Charles Carden" <shadow031449@>
> > wrote:
> > > Just go into Report Maintenance and add a new report. There is
> > need toand
> > > create a new report definition. Then add the report definition
> > correctcan
> > > style, etc. to the report and select it as the default. That
> > now beOn
> > > added to menu.
> > > _____
> > > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]
> > Behalf Ofreport.
> > > Craig Weiss
> > > Sent: Friday, April 11, 2008 1:37 PM
> > > To: vantage@yahoogroups.com
> > > Subject: [Vantage] Menu Item for Report Style
> > > I have created a modified version of the Production Detail
> > Itto
> > > is for our shop supervisors, so I want it to be simple for them
> > run.to
> > > Many people use the production detail report, so I don't want
> > makecustomization
> > > the custom version the default.
> > > Is there a way to create a menu item that will call a
> > > that only has this specific report style, or at least has it asthe
> > > default? I tried creating a new report defenition, but I don'tsee
> > howthis?
> > > to call it from the menu maintenance. Do I need the SDK to do
> > > Thanks,
> > > Craig Weiss
