Working in the Kinetic desktop client. In setting up a Layout, I added a new tab, moved the tab, then tried to move widgets into the tab. This caused the widget to get moved into the tab that was in the position that the new tab was in. It is very confusing, so I made a video. (I hope this works)
Should I post this kind of bug to support? Has anyone else seen this?
Thanks!
Nate
Does it work as expected if you DON’T move the tab first?
But yeah, based on what you’re showing you should report it as a bug. They seem to be moving widgets based on a tab position and not name, which is odd, but… okay.
If that’s the case, then any tab movements should be doing some kind of behind-the-scenes save/update so the widget moves hit the right target.
