Menu Maintenance Customization Field in DB
ver 10.2.600.29
Which Table/Field hold the value for the ‘active customization’ attached to a menu item?
The ‘Menu’ table does not as far as I can tell.
It’s Ice.Menu table, the Arguments column. This is a string of command line-style arguments where “-c XYZABC” indicates which customization is active.
For example, this item is using the “PSG_RMAEntry” customization:
Thank you Tyler, I either forgot or never knew
