Menu Maintenance freezing
Hi Jeff,
Â
I have seen this issue. If i have the menu maintainence open for more than an hour without any activity it does freeze and i have to restart my epicor seesion.
Â
Un fortunately i dont have a resolution for this issue at this minute.
Â
Doma Reddy.Â
Sent: Tuesday, April 16, 2013 11:00 AM
Subject: [Vantage] Menu Maintenance freezing
Â
9.05.701 - Has anybody had any trouble with Menu Maintenance freezing? If I'm in that screen for longer than 2-3 minutes it freezes on me every time which requires shutting down the Epicor session and restarting.
Yes when I open it on our 9.05.700B2 copy it hangs for at least 45 seconds before opening. I've never had it not come up however.
Joshua Giese
CTO
920.437.6400 Ext. 337
Site ID: 27450-E905700B2-SQL64
----- Original Message -----
Sent: Tuesday, April 16, 2013 11:00:26 AM
We had the problem of it freezing on us. To fix the issue we had to go to the Epicor folder on the computer and add full control permissions to Everyone. This fixed the problem. There may be a more specific area to give permissions to.
Jordan
[Bully Dog Logo]<http://www.bullydog.com>
Jordan Klassen | Information Technology
TEL: 940-783-9914 ext: 1828
Confidentiality Notice: The information contained in this electronic message is privileged and confidential information intended only for the use of the individual entity or entities named as recipient or recipients. If the reader is not the intended recipient, you are hereby notified that any dissemination, distribution or copy of this communication is strictly prohibited. If you have received this communication in error, please notify the sender immediately by electronic mail and permanently delete this message from your computer system. Thank you.
Disclaimer added by CodeTwo Exchange Rules 2010
www.codetwo.com<http://www.codetwo.com/?sts=1048>
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Joshua Giese
Sent: Tuesday, April 16, 2013 11:56 AM
Subject: Re: [Vantage] Menu Maintenance freezing
Joshua Giese
CTO
From: "jeff" <jeff.purvis@...<mailto:jeff.purvis%40jtdistributing.com>>
I tried that and it doesn't seem to have fixed the problem. I did however find that if I go into it from a client computer, it does not seem to freeze for some reason. Thanks for the reply.
> Jordan
> Joshua Giese
> CTO
We had an issue where we received an access error. This was due to the
same below where you needed to provide full control permissions for the
person using Epicor on the computer.
Regards,
Sigfredo.
Of jeff
Sent: Tuesday, April 16, 2013 2:45 PM
Subject: [Vantage] Re: Menu Maintenance freezing
> Jordan
system. Thank you.
> Joshua Giese
> CTO
<mailto:jeff.purvis@...%3cmailto:jeff.purvis%40jtdistributing.com> >>
