I want to do a SQL query on menu maintenance to get the form to use field to see which forms have been changed to kinetic and which are still on classic.
I couldn’t find the data in the ice.menu defaultformtype field.
I’ve been using something like the following…
select a.MenuID, a.MenuDesc, a.ParentMenuID, a.Sequence,
case a.DefaultFormType when 'Default' then 'User Choice' when 'Url' then 'Kinetic' when 'Base' then 'Classic' end as MenuType
from Ice.Menu a
where /*ParentMenuID = 'XAMN1000'
and*/ MenuID not in('DNM0000', 'SSMN0000', 'AEEstMng')
