How are others using the Menu Usage Tracker to determine which reports, programs, BAQ’s etc. that are not being used? We are upgrading to Kinetic and the only way I can think of to see which menus are not being used is to copy the usage tracker to excel and then run a BAQ of the menu in Epicor and do a compare? Any other way to see who is not using these menus so we can get rid of a lot of the inactive menus before cutover?
Excel? never heard of it.
I create a BAQ Pivot table to analyze the activity.
SSC1-AT001.baq (33.1 KB)
Thanks Patrick hadn’t thought of that. I can’t use your BAQ because we are on a lower level release but I can go ahead and build one
Thanks again
