The following fix Ted gave me seems to be the one that works. But I have
only tried it on one report. I'll keep my fingers crossed.
Rhonda Reilly
Sent: Wednesday, January 17, 2001 11:56 PM
To: vantage@egroups.com
Subject: Re: [Vantage] Merant 3.5 or Crystal 8
In my case, Seagate had to customize the registry fix for our installation.
I don't know why. It didn't work until one line was changed according to
the driver that was in use when running the report.
Troy Funte
Liberty Electronics
Rhonda Reilly
Troy Funte
Liberty Electronics
----- Original Message -----
To: 'vantage@egroups.com'
Sent: Wednesday, January 17, 2001 7:48 AM
Subject: RE: [Vantage] Merant 3.5 or Crystal 8
I just uploaded a file to eGroups called ivpro14 for 3.5.reg. Download
this
file and it will get rid of the "Unable to understand after DECLARE"
error.
This will need to be run on every machine that has Crystal Reports
installed
on it. You don't need to use it on machines that will just run the
reports.
The error message comes from the way that Crystal formats the SQL
statements
that are passed off to the ODBC driver. This registry file updates the
way
that Crystal formats the SQL statements.
Ted Kitch
tedkitch@...
Sent: Wednesday, January 17, 2001 8:34 AM
Subject: [Vantage] Merant 3.5 or Crystal 8
I upgraded my Crystal reports and the Merant ODBC Driver almost
simultaneously so I can't tell which is causing the problem. I am now
getting the Odbc error "unable to understand after "DECLARE" and have read
from past emails that you can take out the "(" and it will work. Yes that
is true but as I am building my reports (adding tables, joins, filters,
ect)
I am having to go back to the SQL statement hit the reset button and then
take the "(" out again. Is that what I am supposed to do or is there
another way around this problem.
Also thanks to all that answered my question about compiling reports in CR
8.
Thank you
Rhonda
eGroups Sponsor
<http://rd.yahoo.com/M=169066.1281467.2883016.2/D=egroupmail/S=1700007183:N/
A=560436/*http://cgi.timeinc.net/cgi-bin/magsubs/cc/subs/ecompanynowcc1?EFFO
RTKEY=ECABC84> Click Here!
To unsubscribe from this group, send an email to:
vantage-unsubscribe@egroups.com
eGroups Sponsor
