MES Blank Title 87762
We have 20-30 jobs and it works fine.
But we realised that if you just log out and don't clock out for more than a couple of days it gets slower and slower.
Ephraim Feldman
Sender: vantage@yahoogroups.com
Date: Tue, 13 Dec 2011 19:48:03
To: <vantage@yahoogroups.com>
Reply-To: vantage@yahoogroups.com
Subject: [Vantage] Re: MES
Well one of our guys had over 20 open and the system was acting squirly
HI Everyone,
Does anyone know how to prevent a user from clocking onto more than one job at a time on the MES? I am thinking a BPM would work but I am not sure where to start.
Paul
Here's a dumb question... we've gone so long without using the MES side
of Vantage that I don't remember how one logs into it. Can someone
please enlighten me?
Blake Clemens
IT Systems Engineer
Delmarva Millwork Corporation
(800) 360-2364 x132
It is a separate icon from Vantage the target is adding the -MES
C:\client803\client\MfgSys.exe -MES
> Thanks,
> Blake Clemens
> IT Systems Engineer
> (800) 360-2364 x132
V8? Copy your regular shortcut and edit it and put " -MES" at the end of
the command.
Example:
C:\epicor\client8034\client\MfgSys.exe -MES
Edward F. Fox, Jr., CPA
Controller
Maxson Automatic Machinery Company
Phone 401-596-9873 x110 a Fax 401-596-1050
www.maxsonautomatic.com
_____
Blake Clemens
Sent: Wednesday, September 22, 2010 3:21 PM
Subject: [Vantage] MES
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Gotcha, thanks guys.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Of Edward F. Fox, Jr.
Sent: Wednesday, September 22, 2010 3:31 PM
Subject: RE: [Vantage] MES
the command.
Example:
Controller
Phone 401-596-9873 x110 Fax 401-596-1050
_____
Behalf Of
Blake Clemens
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Does anyone know of a way to have multiple MES customization's? We would like one MES screen for Supervisors and another MES screen for the machine operators. What are some of the ways you control something like that? A more specific example might be a 'Material Transfer' It would be nice if the operator could see that button but once pressed it would require credentials from a supervisor? I'm just shooting in the dark I have no clue what I can do with MES.
Create TWO menus for MES one with Cust1 another with Cust2 on the machines
which you need the seocond cust change the MFGSYS file to use the
appropriate menu
That's the easy way,
You can also do what you suggested with some simple logic, maybe a flag or
two in the UserFile record..
*Jose C Gomez*
*Software Engineer*
*checkout my new blog <http://www.usdoingstuff.com> *
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
On Wed, Oct 19, 2011 at 1:51 PM, jgiese1988
> do with MES.
So you can specify which MES customization to open from the MFGSYS file? Interesting, ok something to think about thank you.
> appropriate menu
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > do with MES.
Yep, exactly. In the c:\client803\client\config folder, you have have many XXXX.mfgsys files. Modify your target path on your MES icon to utilize the appropriate .mfgsys file for your MES customization. Look for: <MESCustomMenuID value=""
There’s an Answerbook on this on Epicweb (#5213MPS).
PROBLEM:
How do you customize the main MES Menu and set to use it instead of default?
SOLUTION:
1. Right-click on the shortcut for Vantage 8.0 MES.
2. Copy and paste the copy to the desktop.
3. Rename the copy to something like MES Developer.
4. Right-Click and choose Properties.
5. In the Target area, locate where it shows -MES and change it to -MESC.
6. Click OK to save the changes.
7. Login to MES Developer.
8. Make your customizations and choose Save as
9. Give your customization a name (i.e CustomMES)
10. Save and close MES
11. Log into a your a regular 8.0 session
12. Go to System Management >> Utilites >> Sub Process Maintenance
13. Create a new menu ID and give it a name e.g UDMES1
14. Choose the security you want to apply to this option
15. Enter a parent process like PROCESS or MAINMENU
16. Enter a unique number for the sequence like 10, 15, 20, etc.
17. Under the Program section browse to or type in Epicor.Mfg.Menu.Mes.dll
18. Choose the Customization name you saved in steps 4/5 from the list box
19. Save and close Sub Process Maintenance
20. Create a Process Calling using System Management >> Utilities >> Process Calling Maintenance
21. Choose File >> New
22. Process Called Reference = Epicor.Mfg.Menu.MES
23. Menu ID = UDMES1 (Menu ID create in step 13)
24. Save and close Process Calling Maintenance
25. Add the process ID you just created in step # 13 as the value for the MESCustomMenuID node in the
xxx.mfgsys file being referenced by your MES icon
<MESCustomMenuID value="UDMES1" /> This should be listed under the <appSettings>
</appsettings> section. If the icon does not reference mfgsys use the default.mfgsys found
the ...epicor/client/config directory.
26. Log into 8.0 MES again and you should now see your customization.
Note 1: When first installed you will need to change the xxx.mfgsys file used by each MES user. You'll find
this file in the config directory of the epicor client folder e.g. c:\epicor\mfgsys803\client\config
Note 2: In a standard implementation of Vantage the name of the file being changed is default.mfgsys.
HOWEVER, this can change based on your installation of Vantage. For example if you are running against a
test or pilot database the file maybe named test.mfgsys or pilot.mfgsys. You may want to check the port
number of the appserver that MES is using agains the AppServerURL value="AppServerDC://LAPIZ:8301"
statement in the default.mfgsys.
Note 3: Be sure to change the one in the Vantage client config directory stored on the server. This way
when you install a new release of Vantage and the client folders are updated the modified xxx.mfgsys is
downloaded.
Sent: Wednesday, October 19, 2011 2:04 PM
> appropriate menu
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > do with MES.
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2012.0.1831 / Virus Database: 2092/4560 - Release Date: 10/18/11
Does anyone know if there is a limit how many jobs someone can have active at one time in MES?
I know that I've tested with an operator clocked into 12 jobs at one time
and it seemed to work fine... E9.05.606A
> at one time in MES?
We routinely clock 30 to 50 with one operator.
Sent from my Verizon Wireless 4GLTE Phone
-----Original message-----
To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
Sent: Mon, Dec 12, 2011 22:52:54 GMT+00:00
Subject: Re: [Vantage] MES
> at one time in MES?
