MES Code Question
Aaron,
We have recently upgraded to 405. This customization was developed
and tested in 405. I also put in a call to Epicor today about this.
With the customizations that stop - have any of them stopped more
than once? This one is very hit or miss and I am reluctant to put it
into our live environment until it works all the time in Test.
Have a great day!
Brian
--- In vantage@yahoogroups.com, Aaron Hoyt <aaron.hoyt@...> wrote:
> Brian,
> What version are you running?
> We upgraded this last weekend from 403d to 405 and I have some
> customizations that are running fine for a while and then just
stop.
> You have to restart as you stated to reactivate them. They all
worked
> fine in 403d. I am wondering if it is related to the version you
are
> running?
> Aaron Hoyt
> Vantage Plastics
> bdmang_83 wrote:
> > Good morning,
> > We have added a ucb that displays active payroll employees to the
> > end activity form. The ucb is popluated in the load event for this
> > form. I have created a sub-process and process calling. This
> > customization works about 95% of the time. However sometimes the
ucb
> > does not show up. The only way to get it back is to close out of
the
> > MES and log back in. Below is the code - any suggestions would be
> > appreciated.
> > Thanks - Brian
> > Private Sub EndActForm_Load(ByVal sender As object, ByVal
> > args As EventArgs) Handles EndActForm.Load
> > '// Add Event Handler Code
> > '// ucbEmpEnd uses char09 from the LaborDtl Table
> > '// function fills ucbEmpEnd with active, payroll employees
> > Try
> > Dim recSelected As Boolean
> > Dim whereClause As String ="EmpStatus = 'A' AND Payroll
> > = 'yes'"
> > Dim dsEmp As DataSet =
> > Epicor.Mfg.UI.FormFunctions.SearchFunctions.listLookup
> > (oTrans,"EmpBasicAdapter",recSelected,False,whereClause)
> > If (recSelected) Then
> > 'dsEmp.Tables("EmpBasic").DefaultView.Sort = "Name"
> > ucbEmpEnd.ValueMember = "Name"
> > ucbEmpEnd.DataSource = dsEmp
> > ucbEmpEnd.DisplayMember = "Name"
> > Dim Fields As String() = New String() {"Name"}
> > ucbEmpEnd.SetColumnFilter(fields)
> > ucbEmpEnd.AutoWidthOption =
> > AutoWidthOptions.ControlWidth
> > End If
> > Catch
> > msgbox("See Admin")
> > End Try
> > End Sub
Good morning,
customization works about 95% of the time. However sometimes the ucb
does not show up. The only way to get it back is to close out of the
appreciated.
Thanks - Brian
Try
= 'yes'"
End If
Catch
msgbox("See Admin")
End Try
End Sub
Brian,
customizations that are running fine for a while and then just stop.
You have to restart as you stated to reactivate them. They all worked
fine in 403d. I am wondering if it is related to the version you are
running?
Aaron Hoyt
Vantage Plastics
bdmang_83 wrote:
> Good morning,
> appreciated.
> Thanks - Brian
> Try
> = 'yes'"
> End If
> Catch
> msgbox("See Admin")
> End Try
> End Sub
