Yes, you should have an entry for both the main MES screen and End Activity
in the Sub Process Maintenance screen and the Process Calling Maintenance
screen.
Travis L. McMullen
ERP Specialist
ComSonics, Inc.
Harrisonburg, VA 22801
Phone: 540-434-5965 x1274
Toll Free: 1-800-336-9681 x1274
Mobile: 540-435-1920
Fax: 540-434-9847
E-Mail: tmcmullen@...
screen.
Travis L. McMullen
ERP Specialist
ComSonics, Inc.
Fax: 540-434-9847
On Thu, Nov 17, 2011 at 9:18 AM, Richard <rgraf@...> wrote:
> If I customize the main MES menu and the End Activity form do I then
> deploy each one separately? I was able to deploy themain menu changes by
> following Epicor's procedure.
> --- In vantage@yahoogroups.com, "McMullen, Travis" <tmcmullen@...> wrote:
> > I added a file to the user group under Vantage 8.X Customizations called
> > DeployCustomizationinMES.pdf. I got this from Epicor and followed it when
> > I had to customize End Activity.
> > Travis L. McMullen
> > ERP Specialist
> > ComSonics, Inc.
> > Fax: 540-434-9847
> > On Thu, Nov 17, 2011 at 8:31 AM, Richard <rgraf@...> wrote:
> > > Hi all,
> > > I customized the main MES screen in Vantage 8.03 (deactivated some
> buttons
> > > we don't use) and then went into the End Activity form and customized
> that.
> > > The customization menu(s) prompted me to save each separately which I
> did.
> > > Now, when I deploy the customization, only the main MES screen changes
> are
> > > deployed, not the End Activity form changes.
> > > Can someone walk me through the steps, especially how you need to save
> the
> > > changes, so that my deployed customization is entirely up to date?
> Thanks a
> > > million.
> > > Rick
